How to Adjust V-Brakes
Learn how to adjust the brake pads, cable tension and centering on v-brakes (linear pull).
Video updates
- 02:58 - Lubricate the pivot points with a few drops of Tri-Flow.
Today we’ll learn how to adjust v-brakes, which are otherwise known as linear pull brakes. For this job you’ll need a 5mm allen key, a phillips(+) screwdriver, a strip of sandpaper, and an optional cable puller.
Align Brake Levers
The first step is to set up your brake levers. Start by loosening the clamp, and then align them so that they match the angle of your arms when you’re riding. Once the angle is set, tighten the clamp. If you have smaller hands and your levers are hard to reach, you can set them closer by tightening the reach adjustment screw on most levers.
Remove & Inspect Brake Pads
Start by giving the cable some slack. Tighten the lever’s barrel adjuster in all the way. Then pull the protective rubber back and disconnect the brake cable’s quick release mechanism.
Then remove the pads. V-brake pads have two sets of positioning washers on each side of the brake arm. Be careful to watch how the washers are positioned so that you can re-install them correctly.
Inspect your pads. If they are worn past the indicator line, or have metal poking through the surface, you’ll need to replace them. If they look ok, use your sandpaper to re-surface both pads.
Adjust Brake Arm Tension
Now check your brake arm tension. The brake arms should have good spring tension, which makes them release when you let go of the brake lever. If there isn’t much tension, you may have to increase it on both sides. Undo both bolts one at a time, but don’t remove them completely.
You’ll notice a small piece of metal poking out the backside of the brake. This is the spring, and it slides into one of three holes on your frame or fork. Most brakes work fine in the middle hole. To increase your brake tension, move the spring into the top hole. To decrease the brake tension, move the spring into the bottom hole. Then tighten the mounting bolt.
Install & Align Brake Pads
Now re-install the brake pads, with the washers in the same order as they were before. Align the brake pads so the pad face is flat against the rim. V-brake pads are different from traditional pads in that they don’t require any toe-in. Both the front and rear of the pad should contact the rim at the same time. Because of this, v-brakes will sometimes squeak when applied. If you’ve re-surfaced the pads and they are still noisy, you may have to try a higher quality set of pads.
Take a look from the side to make sure the pad is in line with the rim’s brake surface, and not touching the tire or hanging off the bottom of the rim.
Align Brake Arms
With the pads installed, check the brake arm position. Both arms should be facing straight up and down when the pads are contacting the rim. If they are too wide apart, or two close together, you may have to re-arrange the pad washers.
One set of washers is usually thicker than the other. To correct brakes arms that are too far apart, make sure the smallest set of washers are closest to the pads. To correct brakes arms that are too close together, make sure the largest set of washers are closest to the pads.
Adjust Cable Tension
Now re-connect the cable and adjust the cable tension on the brake arm by pulling the cable through the pinch bolt and tightening. You’ll have to play with this adjustment until your brakes feel good. I like to have mine set so that the pads hit the rim when my lever is pulled about 1/4 of the way.
Brake Arm Centering
Make sure both pads now have equal clearance, and are not rubbing against the rim. Both pads should contact the rim at the same time. If not, you can adjust the centering by tightening or loosening the side adjustment screw with your screwdriver.
Related Links
- Park Tool: Linear Pull Brake Service
- Sheldon Brown: Direct-Pull Brakes
Recommended Tools
- Hozan 4th Hand Cable Puller
- Park Tool HXS-1.2 Hex Wrench Set
- Park Tool Wrench Combo Set
- Park Tool SD-Set Shop Screwdrivers
Categories
Latest post 2 days agoHello guys Just bought a new pair of 700c hybrid wheelset with an inside rim width of 19mm. I have tried to fit schwalbe 700 x 40c tyres on them but the tyres just pop out from the rim when inflated. It seems to be a loose fit. Somebody please advise. Thanks...
Read moreRear hub issue
Latest post 2 days agoI have a 10-year-old 105 rear hub, and one of the pawls is acting up, I cleaned it and relubed the hub pawls but it still won't engage as fast as it did, like one of the pawls isn't working. I think it might be time to get a new hub. I would like one that engages faster but don't want to spend the money for something like the DT Swiss hub, what recommendations do any of you have for a hub? Or i...
Read moreWhat tools have you bought recently?
Latest post 3 days agoI'm slowly eliminated all LBSes in my area as options for servicing, LOL. The latest one has been struck off my list after watching, pained, their approach to removing the axle end caps from a hub with cartridge bearings. Suffice to say, I finally ordered a blind bearing puller kit and a bearing press kit. If you want something done properly, you have to do it yourself! Have you bought any nic...
Read moreModern rims crack at spoke holes
Latest post 4 days agoRecently, I was in one of the local bike shops. Someone had brought a bike back to have the back wheel re-trued. There were actually cracks in the rim, originating from the spoke holes. I have had the same problem with my bike. In past decades you could buy a bike, and the wheels were strong. With modern rims, the aluminum is getting thinner and thinner. Now the rims crack. With heavy riders, a...
Read moreAre all folding tyres made of Kevlar bead?
Latest post 1 week agoHello guys I understand cheaper regular tyres are made with a steel wire bead. But are all folding tyres made of Kevlar bead? I have just purchased a set of tyres as per attached photo and wanted to know if the bead is Kevlar. Can anybody please help? Thanks...
Read moreTire bead won’t seat into rim
Latest post 1 week agoI bought a Tamobyke V20. Both the front and rear tire beads slide off the rim when inflating much at all. How do I get them to sit in there where they belong? Pics attached ty!!! IMG_3164.jpeg (Size: 61.62 KB / Downloads: 41) IMG_3173.jpeg (Size: 46.46 KB / Downloads: 40) ...
Read moreHeadset overtightening
Latest post 1 week agoI have a Fondriest and could not get the headset to tighten without over tightening and then it will not steer properly because of heavy drag on the bars. I replaced the headset with no change so I replaced the steel fork with s Hylix carbon fiber bar and another new heatset and pinch steering head lock. Still it wont adjust properly. it acts as if the bottom headset bearing is too deep in the cup...
Read moreThread busted on right pedal crank
Latest post 2 weeks agoHi Ive joined to specifically ask about a problem which may have been covered before Im sure. My right pedal broke so I had to replace it. Then had issues getting the new pedal to go on straight so I was riding with it slightly at a bend. But then it just came loose and fell off. Problem is now the thread seems busted and the pedal just slots in with no screwing needed because the hole is enlar...
Read moreCup & Cone — Simple & Durable or PITA & Outmoded?
Latest post 3 weeks agoCup and cone hubs have long been considered simple, durable, easily maintained, and reliable. Having messed around with a couple of older hubs tonight, I ended up looking at my sealed-bearing hubs with increased fondness. I'm wondering what other people think. Should we old farts just accept that modern hubs with cartridge bearings are the way forward?...
Read moreTrek domane tyre
Latest post 4 weeks agoHi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read moreFalling back
Latest post 4 weeks agoIn December of 2009 I had a first generation carbon fiber fork break on my road bike and it dropped me right on my forehead. This gave me a very serious concussion and both ER doctors and most neurologists do not take them serious. So it took about two years of my slowly dying since I couldn't even remember to eat before my Cop friend took me to a proper neurologist who diagnosed it as a concussio...
Read moreDerailluer Hanger Alignment Tool
Latest post 4 weeks agoI cannot express enough about the importance of this tool when having to deal with multi speed bicycles. I have been in the bicycle biz in one fashion or the other for over 30 years. Have sold many new bicycles and 90% have been out of wack fresh from the box. With used bikes crossing your path you should just expect it to be bad. And never string new cables without checking the hanger first, ever...
Read moreChain sits on top of chainring when shifting up
Latest post 4 weeks agoHey guys, First post here. I've tried searching, but I don't know what you call this. I have a vintage Schwinn Passage that I picked up a few months ago. At first it worked well, but recently it's been giving me trouble. When I shift, the chain pops into the higher (larger) gear, but then sits on top of the chain ring. What ends up happening is that the chainring will keep turning, and eve...
Read moreWTB Raddler TCS 40c, small cut - repairable?
Latest post 4 weeks agoWent to fix the slow leak on my gravel bike's rear tyre. Found the culprit: a small cut near the middle of the tyre. The good news is it gave me an excuse to order a pair of Panaracer 43c semi-slick GravelKings (most of my local rides are more road-focused) to try out. Meanwhile, I was considering ye olde vulcanised patch repair to the inside of the tyre and superglue to the outside, but I'm thi...
Read moreThreaded Left Crank Arm (Pedal thread)
Latest post 4 weeks agoI shipped my Dawes Super Galaxy home and have just had an unfortunate experience of not being able to re-attach my left Shimano M324 pedal. It looks threaded, but I still have hopes as I think it's only the top couple of rings on the inside. [attachment=5341] From what I can tell the pedal thread is fine. I know there are tools out there to fix a thread. I'm hoping that mine is not so bad that...
Read more
