important: Nuts and bolts on your bike should always be tightened to the manufacturer's specifications.
How to Replace a Cartridge Bottom Bracket
Demonstrates how to remove and install a sealed cartridge bottom bracket.
Video updates
  • 01:30 - The torque specification are actually 25-30 ft-lbs, or 300-360 in-lbs. Check with the manufacturer for exact products specs.
This tutorial will demonstrate how to remove and install a sealed cartridge bottom bracket, found on most modern bicycles. You’ll need to remove both cranks first, so be sure to refer to last week’s crank removal and installation tutorial before you begin.
Required Tools
For this job you’ll need a splined bottom bracket tool and a 32mm headset wrench, or a large adjustable wrench.
Components
A cartridge bottom bracket usually has two main components. The cartridge contains the sealed bearings and spindle, and is usually threaded into the right (or drive side) of your frame. The lockring supports the opposite end of the cartridge and is usually threaded into the left (or non-drive side) of your frame.
Bottom Bracket Removal
Remove the drive side first, using the lockring tool and wrench. On most bikes, the drive side has a left-hand thread, so you’ll need to turn your wrench clockwise to loosen. Once the drive side is removed, the non-drive side should easily loosen and unthread by turning counter-clockwise.
Before installing the new bottom bracket, carefully clean the threads on the inside of your frame, and then apply a thin layer of waterproof grease to the threads on both sides of the frame.
You’ll notice that most bottom brackets have an ‘L’ and ‘R’ written on them to assist in installation.
Bottom Bracket Installation
To install, first thread the new lockring part way into the left side of the frame by turning it clockwise. Don’t tighten the left-side yet.
Thread the cartridge all the way into the right side of the frame by turning it counter-clockwise. Tighten it with about 25-30 foot-pounds of pressure (300-360 inch-pounds) using a torque wrench. Torque specifications vary, so it’s a good idea to check the manufacturer’s website for their exact product specifications.
Now you can finish tightening the left side clockwise until it is nice and snug.
Related Links
Recommended Tools
Categories
I'm slowly eliminated all LBSes in my area as options for servicing, LOL. The latest one has been struck off my list after watching, pained, their approach to removing the axle end caps from a hub with cartridge bearings. Suffice to say, I finally ordered a blind bearing puller kit and a bearing press kit. If you want something done properly, you have to do it yourself! Have you bought any nic...
Read more
Rear hub issue
Latest post 2 hours ago
I have a 10-year-old 105 rear hub, and one of the pawls is acting up, I cleaned it and relubed the hub pawls but it still won't engage as fast as it did, like one of the pawls isn't working. I think it might be time to get a new hub. I would like one that engages faster but don't want to spend the money for something like the DT Swiss hub, what recommendations do any of you have for a hub? Or i...
Read more
Latest post 4 hours ago
Hello guys Just bought a new pair of 700c hybrid wheelset with an inside rim width of 19mm. I have tried to fit schwalbe 700 x 40c tyres on them but the tyres just pop out from the rim when inflated. It seems to be a loose fit. Somebody please advise. Thanks...
Read more
Latest post 24 hours ago
Recently, I was in one of the local bike shops. Someone had brought a bike back to have the back wheel re-trued. There were actually cracks in the rim, originating from the spoke holes. I have had the same problem with my bike. In past decades you could buy a bike, and the wheels were strong. With modern rims, the aluminum is getting thinner and thinner. Now the rims crack. With heavy riders, a...
Read more
Hello guys I understand cheaper regular tyres are made with a steel wire bead. But are all folding tyres made of Kevlar bead? I have just purchased a set of tyres as per attached photo and wanted to know if the bead is Kevlar. Can anybody please help? Thanks...
Read more
I bought a Tamobyke V20. Both the front and rear tire beads slide off the rim when inflating much at all. How do I get them to sit in there where they belong? Pics attached ty!!!   IMG_3164.jpeg (Size: 61.62 KB / Downloads: 40)   IMG_3173.jpeg (Size: 46.46 KB / Downloads: 39) ...
Read more
Headset overtightening
Latest post 1 week ago
I have a Fondriest and could not get the headset to tighten without over tightening and then it will not steer properly because of heavy drag on the bars. I replaced the headset with no change so I replaced the steel fork with s Hylix carbon fiber bar and another new heatset and pinch steering head lock. Still it wont adjust properly. it acts as if the bottom headset bearing is too deep in the cup...
Read more
Hi Ive joined to specifically ask about a problem which may have been covered before Im sure. My right pedal broke so I had to replace it. Then had issues getting the new pedal to go on straight so I was riding with it slightly at a bend. But then it just came loose and fell off. Problem is now the thread seems busted and the pedal just slots in with no screwing needed because the hole is enlar...
Read more
Cup and cone hubs have long been considered simple, durable, easily maintained, and reliable. Having messed around with a couple of older hubs tonight, I ended up looking at my sealed-bearing hubs with increased fondness. I'm wondering what other people think. Should we old farts just accept that modern hubs with cartridge bearings are the way forward?...
Read more
Trek domane tyre
Latest post 3 weeks ago
Hi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read more
Falling back
In December of 2009 I had a first generation carbon fiber fork break on my road bike and it dropped me right on my forehead. This gave me a very serious concussion and both ER doctors and most neurologists do not take them serious. So it took about two years of my slowly dying since I couldn't even remember to eat before my Cop friend took me to a proper neurologist who diagnosed it as a concussio...
Read more
Derailluer Hanger Alignment Tool
I cannot express enough about the importance of this tool when having to deal with multi speed bicycles. I have been in the bicycle biz in one fashion or the other for over 30 years. Have sold many new bicycles and 90% have been out of wack fresh from the box. With used bikes crossing your path you should just expect it to be bad. And never string new cables without checking the hanger first, ever...
Read more
Hey guys, First post here. I've tried searching, but I don't know what you call this. I have a vintage Schwinn Passage that I picked up a few months ago. At first it worked well, but recently it's been giving me trouble. When I shift, the chain pops into the higher (larger) gear, but then sits on top of the chain ring. What ends up happening is that the chainring will keep turning, and eve...
Read more
Went to fix the slow leak on my gravel bike's rear tyre. Found the culprit: a small cut near the middle of the tyre. The good news is it gave me an excuse to order a pair of Panaracer 43c semi-slick GravelKings (most of my local rides are more road-focused) to try out. Meanwhile, I was considering ye olde vulcanised patch repair to the inside of the tyre and superglue to the outside, but I'm thi...
Read more
I shipped my Dawes Super Galaxy home and have just had an unfortunate experience of not being able to re-attach my left Shimano M324 pedal. It looks threaded, but I still have hopes as I think it's only the top couple of rings on the inside. [attachment=5341] From what I can tell the pedal thread is fine. I know there are tools out there to fix a thread. I'm hoping that mine is not so bad that...
Read more
