How to Check for Chain Wear
Demonstrates how to measure a worn out chain using Sheldon Brown’s ruler technique.
One of the most common problems I hear about is chain skip, which is when your pedal slips forward while pedaling under pressure. This is usually either caused by a stiff chain link, worn freehub body, or by a worn chain and freewheel. In this tutorial, we’ll learn how to diagnose a worn drivetrain.
Watch the stiff link tutorial first to make sure that isn’t your problem. Once you’ve ruled out a stiff link it’s time to check if your chain is actually worn. Chains will ‘stretch’ over time, because the pins and bushings start to wear, which causes them to start skipping. There are many tools available that measure chain wear (listed to the right of the video), but the easiest and most accurate way to check is by simply using a ruler.
Measure the Chain
With your chain still on the bike, place the ruler’s ‘0’ inch mark directly above the center of one of your chain pins. Now count 12 complete links. A complete link equals 1 inner and 1 outer. A rivet on a new chain should line up exactly with the 12 inch mark using this method.
Wear Indicators
According to Sheldon Brown, if the rivet is less than 1/16″ past the mark, your chain is ok. If it’s between 1/16″ and 1/8″ past the mark you’ll likely need a new chain, but your sprockets should be ok. If it’s more than 1/8″ past the mark, you’ll have to replace both the chain and rear sprockets.
Cassettes & Freewheels
The reason you’d have to replace the rear sprockets is because they generally wear with the chain. While the chain is ‘stretching’, the gap between the teeth on your sprockets also gets wider and wider. This causes the chain to ride up over the teeth and slip while pedaling under pressure. If you install a new chain on an old sprocket, you’ll probably be able to see gaps of light through the teeth as shown. Here’s how to replace a cassette or a freewheel.
Front Chainrings
Your front chainrings generally won’t need replacing. Because of the larger diameter, the front chainrings usually take twice as long to wear. If worn they are very easy to spot, as they’ll start looking like shark teeth. Here’s how to replace your chainrings.
Credits
Thanks to Sheldon Brown and Cambridge Cycling Campaign for the photos!
Related Links
Recommended Tools
- Park Tool CT-5 Chain Tool
- Park Tool CT-3 Chain Tool
- Park Tool CC-3.2 Chain Checker
- Park Tool CC-2 Chain Checker
- Wippermann Chain Wear Indicator
- Park Tool CG-2 Chain Gang Chain Cleaning System
Categories
Rear hub issue
Latest post 2 days agoI have a 10-year-old 105 rear hub, and one of the pawls is acting up, I cleaned it and relubed the hub pawls but it still won't engage as fast as it did, like one of the pawls isn't working. I think it might be time to get a new hub. I would like one that engages faster but don't want to spend the money for something like the DT Swiss hub, what recommendations do any of you have for a hub? Or i...
Read moreTyres keep popping off wheels...
Latest post 1 week agoHello guys Just bought a new pair of 700c hybrid wheelset with an inside rim width of 19mm. I have tried to fit schwalbe 700 x 40c tyres on them but the tyres just pop out from the rim when inflated. It seems to be a loose fit. Somebody please advise. Thanks...
Read moreWhat tools have you bought recently?
Latest post 1 week agoI'm slowly eliminated all LBSes in my area as options for servicing, LOL. The latest one has been struck off my list after watching, pained, their approach to removing the axle end caps from a hub with cartridge bearings. Suffice to say, I finally ordered a blind bearing puller kit and a bearing press kit. If you want something done properly, you have to do it yourself! Have you bought any nic...
Read moreModern rims crack at spoke holes
Latest post 1 week agoRecently, I was in one of the local bike shops. Someone had brought a bike back to have the back wheel re-trued. There were actually cracks in the rim, originating from the spoke holes. I have had the same problem with my bike. In past decades you could buy a bike, and the wheels were strong. With modern rims, the aluminum is getting thinner and thinner. Now the rims crack. With heavy riders, a...
Read moreAre all folding tyres made of Kevlar bead?
Latest post 2 weeks agoHello guys I understand cheaper regular tyres are made with a steel wire bead. But are all folding tyres made of Kevlar bead? I have just purchased a set of tyres as per attached photo and wanted to know if the bead is Kevlar. Can anybody please help? Thanks...
Read moreTire bead won’t seat into rim
Latest post 2 weeks agoI bought a Tamobyke V20. Both the front and rear tire beads slide off the rim when inflating much at all. How do I get them to sit in there where they belong? Pics attached ty!!! IMG_3164.jpeg (Size: 61.62 KB / Downloads: 42) IMG_3173.jpeg (Size: 46.46 KB / Downloads: 41) ...
Read moreHeadset overtightening
Latest post 2 weeks agoI have a Fondriest and could not get the headset to tighten without over tightening and then it will not steer properly because of heavy drag on the bars. I replaced the headset with no change so I replaced the steel fork with s Hylix carbon fiber bar and another new heatset and pinch steering head lock. Still it wont adjust properly. it acts as if the bottom headset bearing is too deep in the cup...
Read moreThread busted on right pedal crank
Latest post 3 weeks agoHi Ive joined to specifically ask about a problem which may have been covered before Im sure. My right pedal broke so I had to replace it. Then had issues getting the new pedal to go on straight so I was riding with it slightly at a bend. But then it just came loose and fell off. Problem is now the thread seems busted and the pedal just slots in with no screwing needed because the hole is enlar...
Read moreCup & Cone — Simple & Durable or PITA & Outmoded?
Latest post 3 weeks agoCup and cone hubs have long been considered simple, durable, easily maintained, and reliable. Having messed around with a couple of older hubs tonight, I ended up looking at my sealed-bearing hubs with increased fondness. I'm wondering what other people think. Should we old farts just accept that modern hubs with cartridge bearings are the way forward?...
Read moreTrek domane tyre
Latest post 1 month agoHi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read moreFalling back
Latest post 1 month agoIn December of 2009 I had a first generation carbon fiber fork break on my road bike and it dropped me right on my forehead. This gave me a very serious concussion and both ER doctors and most neurologists do not take them serious. So it took about two years of my slowly dying since I couldn't even remember to eat before my Cop friend took me to a proper neurologist who diagnosed it as a concussio...
Read moreDerailluer Hanger Alignment Tool
Latest post 1 month agoI cannot express enough about the importance of this tool when having to deal with multi speed bicycles. I have been in the bicycle biz in one fashion or the other for over 30 years. Have sold many new bicycles and 90% have been out of wack fresh from the box. With used bikes crossing your path you should just expect it to be bad. And never string new cables without checking the hanger first, ever...
Read moreChain sits on top of chainring when shifting up
Latest post 1 month agoHey guys, First post here. I've tried searching, but I don't know what you call this. I have a vintage Schwinn Passage that I picked up a few months ago. At first it worked well, but recently it's been giving me trouble. When I shift, the chain pops into the higher (larger) gear, but then sits on top of the chain ring. What ends up happening is that the chainring will keep turning, and eve...
Read moreWTB Raddler TCS 40c, small cut - repairable?
Latest post 1 month agoWent to fix the slow leak on my gravel bike's rear tyre. Found the culprit: a small cut near the middle of the tyre. The good news is it gave me an excuse to order a pair of Panaracer 43c semi-slick GravelKings (most of my local rides are more road-focused) to try out. Meanwhile, I was considering ye olde vulcanised patch repair to the inside of the tyre and superglue to the outside, but I'm thi...
Read moreThreaded Left Crank Arm (Pedal thread)
Latest post 1 month agoI shipped my Dawes Super Galaxy home and have just had an unfortunate experience of not being able to re-attach my left Shimano M324 pedal. It looks threaded, but I still have hopes as I think it's only the top couple of rings on the inside. [attachment=5341] From what I can tell the pedal thread is fine. I know there are tools out there to fix a thread. I'm hoping that mine is not so bad that...
Read more
