How to Replace Handlebar Grips
Learn how to easily remove handlebar grips and re-install them so they stay in place.
This week we’ll learn how to remove and install handlebar grips. For this job, you’ll need some replacement grips, a long, slim screwdriver or similar metal tool, a 5 or 6mm allen key to loosen your levers and shifters, some hairspray, and some WD-40 to loosen the old grips. While I don’t recommend using WD-40 as a lubricant anywhere on your bike, this is one of the few times where it works well.
Grip Removal
If you have bar-plugs you should remove these first. You’ll also likely have to loosen the brake and shift levers and slide them in toward the middle of the handlebar. This will give us room to slide our screwdriver into the end of the grip.
Once you’ve got the screwdriver inside the grip, insert the WD-40 tube and give it a squirt or two. It doesn’t take much get the grip loose enough so that you can easily wiggle it all the way off the end of the bar.
Before installing the new grips, make sure you wipe all off the bars first. If you’re reinstalling the old grips, make sure you let the grip air-dry for a few minutes first so the WD-40 you used to remove it has time to evaporate.
Grip Installation
Now spray a squirt or two of hairspray into the grip, and quickly work it onto the bar while the hairspray is still wet. It’ll dry sticky and keep your grips in place. Then move your brake and shift levers back to where they were and tighten them.
Related Links
Recommended Tools
- Park Tool SD-Set Shop Screwdrivers
- Park Tool WTK-2 Essential Tool Kit
Categories
Problems with new 3x7 trigger shifter (ST EF51) on 3 side
Latest post 5 hours agoHi, I am new to working on bicycle gears and am hoping to get some help determining if my new shifter has failed or if I just need to make some more adjustments. On the left side shifter, I am able to shift easily from 1st to 2nd, but when I tried to get it to go to 3rd, the chain would go up, but the shifter wouldn't lock into place. It would be great thumb exercise, but I prefer to fix it. I...
Read moreWhat tools have you bought recently?
Latest post 1 day agoI'm slowly eliminated all LBSes in my area as options for servicing, LOL. The latest one has been struck off my list after watching, pained, their approach to removing the axle end caps from a hub with cartridge bearings. Suffice to say, I finally ordered a blind bearing puller kit and a bearing press kit. If you want something done properly, you have to do it yourself! Have you bought any nic...
Read moreRear hub issue
Latest post 2 days agoI have a 10-year-old 105 rear hub, and one of the pawls is acting up, I cleaned it and relubed the hub pawls but it still won't engage as fast as it did, like one of the pawls isn't working. I think it might be time to get a new hub. I would like one that engages faster but don't want to spend the money for something like the DT Swiss hub, what recommendations do any of you have for a hub? Or i...
Read moreHeadset overtightening
Latest post 3 days agoI have a Fondriest and could not get the headset to tighten without over tightening and then it will not steer properly because of heavy drag on the bars. I replaced the headset with no change so I replaced the steel fork with s Hylix carbon fiber bar and another new heatset and pinch steering head lock. Still it wont adjust properly. it acts as if the bottom headset bearing is too deep in the cup...
Read moreSpecialized expedition in need of repair
Latest post 3 days agoHello I have recently pulled my 2005 specialized expedition out of the garage. It's in need of some repair due to it being damaged by super storm sandy. My shed was flooded with ocean water. The frame itself looks perfect but the moving parts have some rust. Including the fork, brakes, and gears. I'm just looking for replacement parts I have no intentions on buying a new bike. Please help than...
Read moreTyres keep popping off wheels...
Latest post 2 weeks agoHello guys Just bought a new pair of 700c hybrid wheelset with an inside rim width of 19mm. I have tried to fit schwalbe 700 x 40c tyres on them but the tyres just pop out from the rim when inflated. It seems to be a loose fit. Somebody please advise. Thanks...
Read moreModern rims crack at spoke holes
Latest post 3 weeks agoRecently, I was in one of the local bike shops. Someone had brought a bike back to have the back wheel re-trued. There were actually cracks in the rim, originating from the spoke holes. I have had the same problem with my bike. In past decades you could buy a bike, and the wheels were strong. With modern rims, the aluminum is getting thinner and thinner. Now the rims crack. With heavy riders, a...
Read moreAre all folding tyres made of Kevlar bead?
Latest post 4 weeks agoHello guys I understand cheaper regular tyres are made with a steel wire bead. But are all folding tyres made of Kevlar bead? I have just purchased a set of tyres as per attached photo and wanted to know if the bead is Kevlar. Can anybody please help? Thanks...
Read moreTire bead won’t seat into rim
Latest post 4 weeks agoI bought a Tamobyke V20. Both the front and rear tire beads slide off the rim when inflating much at all. How do I get them to sit in there where they belong? Pics attached ty!!! IMG_3164.jpeg (Size: 61.62 KB / Downloads: 42) IMG_3173.jpeg (Size: 46.46 KB / Downloads: 41) ...
Read moreThread busted on right pedal crank
Latest post 4 weeks agoHi Ive joined to specifically ask about a problem which may have been covered before Im sure. My right pedal broke so I had to replace it. Then had issues getting the new pedal to go on straight so I was riding with it slightly at a bend. But then it just came loose and fell off. Problem is now the thread seems busted and the pedal just slots in with no screwing needed because the hole is enlar...
Read moreCup & Cone — Simple & Durable or PITA & Outmoded?
Latest post 1 month agoCup and cone hubs have long been considered simple, durable, easily maintained, and reliable. Having messed around with a couple of older hubs tonight, I ended up looking at my sealed-bearing hubs with increased fondness. I'm wondering what other people think. Should we old farts just accept that modern hubs with cartridge bearings are the way forward?...
Read moreTrek domane tyre
Latest post 1 month agoHi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read moreFalling back
Latest post 1 month agoIn December of 2009 I had a first generation carbon fiber fork break on my road bike and it dropped me right on my forehead. This gave me a very serious concussion and both ER doctors and most neurologists do not take them serious. So it took about two years of my slowly dying since I couldn't even remember to eat before my Cop friend took me to a proper neurologist who diagnosed it as a concussio...
Read moreDerailluer Hanger Alignment Tool
Latest post 1 month agoI cannot express enough about the importance of this tool when having to deal with multi speed bicycles. I have been in the bicycle biz in one fashion or the other for over 30 years. Have sold many new bicycles and 90% have been out of wack fresh from the box. With used bikes crossing your path you should just expect it to be bad. And never string new cables without checking the hanger first, ever...
Read moreChain sits on top of chainring when shifting up
Latest post 1 month agoHey guys, First post here. I've tried searching, but I don't know what you call this. I have a vintage Schwinn Passage that I picked up a few months ago. At first it worked well, but recently it's been giving me trouble. When I shift, the chain pops into the higher (larger) gear, but then sits on top of the chain ring. What ends up happening is that the chainring will keep turning, and eve...
Read more
