How to Assemble a New Bike
Overview of a boxed bike assembly. Shows how to put together a mail-order bike.
These days you can get a great deal on a new bike by ordering online. Today we’ll learn how to properly assemble a mail order bike right out of the box. Since there are so many different types of bikes and components available, I’ll give a brief overview of the assembly. If you’re watching this video on bikeride.com, you can check the links in the text below for more specific instructions.
Tools
For this job you’ll need several tools. Ideally you should have a repair stand and a wheel truing stand. Other necessary tools include wire cutters, a set of metric allen keys, a set of metric open-end wrenches, flathead (-) and phillips (+) screwdrivers, cone wrenches, a pedal wrench and an air pump. You’ll also need some waterproof grease, chain oil and a rag.
Unpacking
Open the top flap and carefully pull everything out of the box. Apply some grease to the inside of the seat tube, slide the seatpost in to the minimum insertion mark, grease the threads of the seatpost bolt and tighten it just enough so it will hold the weight of the bike. Then clamp the seatpost in your repair stand.
Remove the front wheel by using wire cutters to carefully snip the zip ties. To save these for future use, cut them just before the head and then pull out and recycle the remaining piece of zip-tie. This leaves you with a short piece of zip-tie that can be used again for odd jobs. Remove the rest of the packaging and either recycle it, or save it so you can box your bike up in the future.
Assembly
If your headset and bottom bracket have loose ball bearings, open them up and check for grease and adjust as needed. If you have sealed cartridge bearings in these places you can skip this step.
Now we’re ready to install the handlebar. Grease all of the stem bolt threads and shaft if you’re installing an older quill-style stem. Then center the handlebar and tighten the stem bolts evenly so the gap is equal on both sides. Tighten the top cap just enough to hold it in place.
Remove the rear wheel and cassette or freewheel, and open the hubs on both wheels to check for grease. Add more grease as needed and then adjust the hub cones so they spin freely with very little play. See the hub overhaul tutorial for adjustment instructions. Grease the cassette or freewheel’s threads before re-installing them.
Watch the wheel-truing tutorial to see how to de-stress and true the wheels. Then inflate the tires to the recommended pressure and install both wheels on the bike.
It’s a good idea to grease the threads of the crank bolts, chainring bolts, and other bolts that hold accessories like water bottle cages. This will help them repel water and dirt and stop them from seizing up. Grease the pedal threads and install them. Remember that the left pedal always has a reverse thread, so you have to tighten it by turning counter-clockwise.
Set up and adjust your brakes. See the brake tutorials page for set-up instructions on specific brake types. Then lube the chain and adjust the derailleurs. Watch the front and rear derailleur tutorials to see how.
Apply any stickers and/or accessories and then remove the bike from the stand. Adjust your seat height and angle, align your handlebars and adjust your headset. See the headsets and handlebars pages for related tutorials… and then get out for ride!
Related Links
- Mtn Bike Riders: Mail-Order Bike Assembly
- Park Tool: New Bike Assembly
Recommended Tools
- Park Tool PCS-9 Repair Stand
- Park Tool PCS-4 Repair Stand
- Park Tool TS-8 Home Truing Stand
- Park Tool TS-2.2 Home Truing Stand
Categories
Latest post 1 day agoJust picked up this little classic 1990 Brompton Mk2 with Sturmey-Archer 3-speed hub. Needs some TLC but all the important bits seem to be in reasonable condition with no signs of substantial rust on frame, rear triangle, or hubs. Not only do I look forward to learning The Way of The Brompton, but this means I'll probably be buying more tools. WINNING! WhatsApp Image 2024-05-11 at 1...
Read moreJeanne (Robinson) Omelenchuk’s custom 1960 road racing bike
Latest post 1 day agoCheck out the work that went into "Jeanne (Robinson) Omelenchuk’s custom 1960 road racing bike" here: http://classiccycleus.com/home/repair/museum-bikes-1945-to-1979/ To whit: "George cast the aluminum hub shells himself, producing hubs that were extremely wide by the standards of the day (heck, they’re wide by today’s standards, and we pack 11 cogs onto modern rear hubs). The rims were dra...
Read moreHow to disassemble SR Suntour xct-mlo fork
Latest post 5 days agoWas given a 2013 GT Karakoram 4.0. Fork moves fairly well but starting to squeak and needs service. MLO works. How do I take apart the MLO side? Lots of videos show the SR Suntour xct with a smooth blue lockout cap. It has a lockring and you have to pry it up evenly Not sure if this one is also a pry up. The notches look the same on both sides. Wrench fits on the spring/preload side and unscrews...
Read moreProblems with new 3x7 trigger shifter (ST EF51) on 3 side
Latest post 2 weeks agoHi, I am new to working on bicycle gears and am hoping to get some help determining if my new shifter has failed or if I just need to make some more adjustments. On the left side shifter, I am able to shift easily from 1st to 2nd, but when I tried to get it to go to 3rd, the chain would go up, but the shifter wouldn't lock into place. It would be great thumb exercise, but I prefer to fix it. I...
Read moreWhat tools have you bought recently?
Latest post 2 weeks agoI'm slowly eliminated all LBSes in my area as options for servicing, LOL. The latest one has been struck off my list after watching, pained, their approach to removing the axle end caps from a hub with cartridge bearings. Suffice to say, I finally ordered a blind bearing puller kit and a bearing press kit. If you want something done properly, you have to do it yourself! Have you bought any nic...
Read moreRear hub issue
Latest post 2 weeks agoI have a 10-year-old 105 rear hub, and one of the pawls is acting up, I cleaned it and relubed the hub pawls but it still won't engage as fast as it did, like one of the pawls isn't working. I think it might be time to get a new hub. I would like one that engages faster but don't want to spend the money for something like the DT Swiss hub, what recommendations do any of you have for a hub? Or i...
Read moreHeadset overtightening
Latest post 2 weeks agoI have a Fondriest and could not get the headset to tighten without over tightening and then it will not steer properly because of heavy drag on the bars. I replaced the headset with no change so I replaced the steel fork with s Hylix carbon fiber bar and another new heatset and pinch steering head lock. Still it wont adjust properly. it acts as if the bottom headset bearing is too deep in the cup...
Read moreSpecialized expedition in need of repair
Latest post 2 weeks agoHello I have recently pulled my 2005 specialized expedition out of the garage. It's in need of some repair due to it being damaged by super storm sandy. My shed was flooded with ocean water. The frame itself looks perfect but the moving parts have some rust. Including the fork, brakes, and gears. I'm just looking for replacement parts I have no intentions on buying a new bike. Please help than...
Read moreTyres keep popping off wheels...
Latest post 4 weeks agoHello guys Just bought a new pair of 700c hybrid wheelset with an inside rim width of 19mm. I have tried to fit schwalbe 700 x 40c tyres on them but the tyres just pop out from the rim when inflated. It seems to be a loose fit. Somebody please advise. Thanks...
Read moreModern rims crack at spoke holes
Latest post 1 month agoRecently, I was in one of the local bike shops. Someone had brought a bike back to have the back wheel re-trued. There were actually cracks in the rim, originating from the spoke holes. I have had the same problem with my bike. In past decades you could buy a bike, and the wheels were strong. With modern rims, the aluminum is getting thinner and thinner. Now the rims crack. With heavy riders, a...
Read moreAre all folding tyres made of Kevlar bead?
Latest post 1 month agoHello guys I understand cheaper regular tyres are made with a steel wire bead. But are all folding tyres made of Kevlar bead? I have just purchased a set of tyres as per attached photo and wanted to know if the bead is Kevlar. Can anybody please help? Thanks...
Read moreTire bead won’t seat into rim
Latest post 1 month agoI bought a Tamobyke V20. Both the front and rear tire beads slide off the rim when inflating much at all. How do I get them to sit in there where they belong? Pics attached ty!!! IMG_3164.jpeg (Size: 61.62 KB / Downloads: 52) IMG_3173.jpeg (Size: 46.46 KB / Downloads: 51) ...
Read moreThread busted on right pedal crank
Latest post 1 month agoHi Ive joined to specifically ask about a problem which may have been covered before Im sure. My right pedal broke so I had to replace it. Then had issues getting the new pedal to go on straight so I was riding with it slightly at a bend. But then it just came loose and fell off. Problem is now the thread seems busted and the pedal just slots in with no screwing needed because the hole is enlar...
Read moreCup & Cone — Simple & Durable or PITA & Outmoded?
Latest post 2 months agoCup and cone hubs have long been considered simple, durable, easily maintained, and reliable. Having messed around with a couple of older hubs tonight, I ended up looking at my sealed-bearing hubs with increased fondness. I'm wondering what other people think. Should we old farts just accept that modern hubs with cartridge bearings are the way forward?...
Read moreTrek domane tyre
Latest post 2 months agoHi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read more
