How to Replace Cotterless Crank Arms
Crank removal and installation procedure on a square-spindle, sealed bottom bracket.
Video updates
- 02:08 - The crank bolts should be torqued to about 35 foot-pounds, or 420 inch-pounds.
This tutorial will demonstrate how to remove and install square-spindled crank arms. I’ve based this tutorial on cranks attached to a sealed cartridge bottom bracket. I’ll cover the loose-bearing style in a future tutorial.
Tools Required
To remove the bolt, you’ll need either an 8mm allen key or 14mm socket wrench. To remove the crank arms, you’ll need a crank puller, a 16mm open-end wrench, and an adjustable wrench. If possible, a torque wrench should also be used for tightening.
Crank Arm Removal
In order to safely remove the right side, you’ll have to shift the front derailleur onto the smallest chainring, and then carefully remove the chain and rest it on the bottom bracket, so that it doesn’t interfere with the crank arm removal.
Using the crank arm for leverage, loosen and remove the tightening bolt with your allen key or 14mm socket wrench. Be careful not to skin your knuckles on the chainring teeth.
Before using the crank puller, make sure it is fully extended so that the internal driver does not extend past the external threads.
Note: If crank threads are damaged, there are a few solutions at Park Tools.
Carefully thread the external threads of the crank puller clockwise into the crank arm. Avoid cross-threading, which will damage the crank and prevent future removal.
Once the crank puller is fully threaded, place the adjustable wrench on the external flats and turn the internal driver clockwise until it stops. Turn the driver clockwise using a 16mm wrench, until the crank arm pulls free of the spindle. Repeat the same process to remove the left crank arm.
Crank Arm Installation
Before re-installing the cranks wipe both the square spindle and the crank’s spindle fitting to make sure there is no dirt or grease on either surface.
Now slide the right crank’s spindle fitting onto the spindle. Before installing the bolts, grease under the head and along the threads of both bolts. Thread the bolt all the way into the spindle threads and torque the bolt to about 35 foot-pounds, or 420 inch-pounds.
Set the chain back on the chainring and repeat the same installation procedure on the left side, making sure the crank arm is pointing opposite the right side.
Related Links
- Park Tool: Bicycle Torque Specifications
- Park Tool: Crank Installation and Removal
- Sheldon Brown: Cotterless Cranks
Recommended Tools
- Shimano TL-FC10 Crank Extractor
- Park Tool Wrench Combo Set
- Park Tool PAW-12 Adjustable Wrench
- Park Tool WTK-2 Essential Tool Kit
Categories
Latest post 6 hours agoI'm slowly eliminated all LBSes in my area as options for servicing, LOL. The latest one has been struck off my list after watching, pained, their approach to removing the axle end caps from a hub with cartridge bearings. Suffice to say, I finally ordered a blind bearing puller kit and a bearing press kit. If you want something done properly, you have to do it yourself! Have you bought any nic...
Read moreThread busted on right pedal crank
Latest post 4 days agoHi Ive joined to specifically ask about a problem which may have been covered before Im sure. My right pedal broke so I had to replace it. Then had issues getting the new pedal to go on straight so I was riding with it slightly at a bend. But then it just came loose and fell off. Problem is now the thread seems busted and the pedal just slots in with no screwing needed because the hole is enlar...
Read moreTrek domane tyre
Latest post 4 days agoHi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read moreModern rims crack at spoke holes
Latest post 4 days agoRecently, I was in one of the local bike shops. Someone had brought a bike back to have the back wheel re-trued. There were actually cracks in the rim, originating from the spoke holes. I have had the same problem with my bike. In past decades you could buy a bike, and the wheels were strong. With modern rims, the aluminum is getting thinner and thinner. Now the rims crack. With heavy riders, a...
Read moreCup & Cone — Simple & Durable or PITA & Outmoded?
Latest post 4 days agoCup and cone hubs have long been considered simple, durable, easily maintained, and reliable. Having messed around with a couple of older hubs tonight, I ended up looking at my sealed-bearing hubs with increased fondness. I'm wondering what other people think. Should we old farts just accept that modern hubs with cartridge bearings are the way forward?...
Read moreFalling back
Latest post 4 days agoIn December of 2009 I had a first generation carbon fiber fork break on my road bike and it dropped me right on my forehead. This gave me a very serious concussion and both ER doctors and most neurologists do not take them serious. So it took about two years of my slowly dying since I couldn't even remember to eat before my Cop friend took me to a proper neurologist who diagnosed it as a concussio...
Read moreDerailluer Hanger Alignment Tool
Latest post 4 days agoI cannot express enough about the importance of this tool when having to deal with multi speed bicycles. I have been in the bicycle biz in one fashion or the other for over 30 years. Have sold many new bicycles and 90% have been out of wack fresh from the box. With used bikes crossing your path you should just expect it to be bad. And never string new cables without checking the hanger first, ever...
Read moreChain sits on top of chainring when shifting up
Latest post 4 days agoHey guys, First post here. I've tried searching, but I don't know what you call this. I have a vintage Schwinn Passage that I picked up a few months ago. At first it worked well, but recently it's been giving me trouble. When I shift, the chain pops into the higher (larger) gear, but then sits on top of the chain ring. What ends up happening is that the chainring will keep turning, and eve...
Read moreWTB Raddler TCS 40c, small cut - repairable?
Latest post 4 days agoWent to fix the slow leak on my gravel bike's rear tyre. Found the culprit: a small cut near the middle of the tyre. The good news is it gave me an excuse to order a pair of Panaracer 43c semi-slick GravelKings (most of my local rides are more road-focused) to try out. Meanwhile, I was considering ye olde vulcanised patch repair to the inside of the tyre and superglue to the outside, but I'm thi...
Read moreThreaded Left Crank Arm (Pedal thread)
Latest post 4 days agoI shipped my Dawes Super Galaxy home and have just had an unfortunate experience of not being able to re-attach my left Shimano M324 pedal. It looks threaded, but I still have hopes as I think it's only the top couple of rings on the inside. [attachment=5341] From what I can tell the pedal thread is fine. I know there are tools out there to fix a thread. I'm hoping that mine is not so bad that...
Read moreUpgrading The Vilano Diverse 3.0 DriveTrain
Latest post 1 week agoI bought this Vilano Hybrid in 2020 as my “old person’s Chinese Cheapie”. It was - (and is) - FAR from equaling the “serious” bikes that I owned back in the 1990’s. The first Trek I had was a gorgeous blue road bike - worthy of all the gawkers it inspired. My Klein Pro Race MTB was the finest all-round “terrain-chewing animal” I ever mounted. It never failed. It never said...
Read moreCrankarm for Diamondback
Latest post 3 weeks agoWill a FC-CT93 fit a FC-TY40 crank arm...
Read moreMy inexpensive strong 29 inch wheel
Latest post 4 weeks agoI am heavier than many cyclists. I ride longer distances then many cyclists. A lot of my riding is on rough tracks. While riding my 29 inch mountain bike, spokes broke in the back wheel. https://forums.bikeride.com/thread-8373.html I replaced them with 3 mm spokes. Not long after, cracks formed in the aluminum rim in two places. It became obvious, I could not go on repairing this wheel. I came...
Read moreNew Wheel Question
Latest post 4 weeks agoI just ordered and received new wheels for my bike. Both the old and new are TLR, but I run with tubes. On my old rim, tape is installed. So…when I ordered the new wheels, I also ordered tape. Today, when the new wheels arrived, I noticed that both included a plastic (?) rim strip. I installed the strip on both rims, which gets me to my question…. Do I also need the rim tape? I would think not...
Read more
