ABUS CityChain 1010
89/100
We have read all expert and user reviews on the ABUS CityChain 1010. In summary, this is what cyclists think.
6 reasons to buy
  • Testers demonstrated that the CityChain 1010’s 9mm thick hardened steel chain can hold up for minutes against attacks using aggressive tools, in real-world conditions.
  • Like all chain locks, the CityChain 1010 provides flexibility in locking situations and portability.
  • The CityChain 1010 comes in four different lengths:
    • 85cm (34”)
    • 110cm (43”)
    • 140cm (55”)
    • 170cm (67”)
  • Experts and users like that the CityChain 1010 has a fabric sleeve to provide protection for bike frames and components.
  • ABUS’ Plus lock cylinder protects against manipulations such as picking.
  • The CityChain 1010 received a ‘Gold’ rating (for high theft-resistance) from the security certification body Sold Secure. It has also been approved by ART.
3 reasons not to buy
  • Other bike locks weighing slightly more than the CityChain 1010 will hold up to significantly more abuse from thieves.
  • The CityChain is susceptible to attack by sledgehammer, angle grinder or bolt cutters.
  • With weights varying from 4.08 lb to 7.05 lb, some experts and users found this lock to be on the cusp of being too heavy to carry around as a cyclist.
The CityChain 1010 is a reasonable and respected choice for an upper-tier bike lock. While it doesn’t offer the same security and light weight as a U-lock, it’s much easier to find a place to lock your bike. Ranging from four to seven pounds, the weight may be an issue for some riders and commuters. However, for e-bikers, the CityChain 1010 might just be a great choice. For even higher security (but also more weight), you might look to ABUS’ own ‘Granit CityChain XPlus’ range.
Lock Type
4.08, 4.85, 5.84, 7.05 lb
Diameter / Thickness
9 mm
Length
33.5, 43.3, 55.1, 66.9 Inches
Color
Material
Hardened Steel
79/100 based on 3 rated expert reviews
Cyclingnews
ABUS CityChain 1010 Lock Review
For those looking for the most flexible, most portable answer to high-level bike security, then the super heavy duty CityChain 1010 is definitely one of the best. It weighs a ton.
Stiftung Warentest
Bicycle Locks – But Safe! CityChain 1010/110 Black [German]
First place out of five (for chain locks):
  • Security: good
  • Handling: satisfactory
  • Durability: very good
  • Pollutants: good
Bicycle Lock ABUS CityChain 1010 – Review [German]
The Abus CityChain 1010 is a high-quality and very secure chain lock, which is suitable for securing high-quality e-bikes and bicycles. Sometimes you have to be creative when transporting the lock.
Abus Bordo, GRANIT Plus and CityChain Unboxing:
Locks for Lockdown Special!
You’ve got 9mm hex-section hardened links, full fabric cover. It’s heavy. This chain gives you a bit more flexibility in what you can lock to and how you can carry it and it’s really hard to burst. Ideally, you want a D-lock and you want a CityChain like this.
ABUS Locks Chain 1010 Key City Bike Lock – Review
It comes with picking protection so you cannot actually pick the lock.
BikeSocial
Tested: ABUS CityChain 1010 Review
The weakness of the CityChain 1010’s lock body when attacked with a sledge hammer means it’s very important to keep it off the ground, though we strongly recommend this with all locks.
90/100 based on 1517 ratings
    71%
    18%
    6%
    2%
    4%
Bike Lock Comparison
ABUS CityChain 1010 in comparison to averages
Discuss which bike lock to choose in the forum
