BikeRide works hard to help you find the lowest prices and information on each bike from the widest possible range of sources. BikeRide is reader-supported, and sometimes we receive commissions for links you click on. Read Privacy Policy
If you find a lower price, email us at contact@bikeride.com with documentation of the price. We’re committed to making sure that the cost of a bike does not keep you from cycling!
We have read all expert and user reviews on the Addmotor M-66 R7. In summary, this is what cyclists think.
18 reasons to buy
Owners and testers say the 750W Bafang motor delivers plenty of torque, even when carrying a passenger.
The padded chopper saddle is "comfortable" and suitable for carrying an extra passenger.
An expert covers 30 miles and 1,480 feet of elevation at 17.5mph.
The stability and comfort at high speeds impress one reviewer.
Some riders find the M-66 R7 handles well on light off-road trails.
The M-66 R7 is blessed with foldable passenger footpegs.
An expert praises the "impressive" throttle acceleration. Riders can use it from a dead stop.
The Addshox 80mm suspension fork and 4" tires help to smooth out bumpy roads and trails.
Owners admire the retro moped styling of the M-66 R7.
The M-66 R7‘s display is clear and comprehensive.
The Tektro Aries mechanical brakes perform "excellently" in brake tests. A motor cut-off switch aids with stopping.
The M-66 R7 Cruiser is available in four attractive colors.
The battery can be removed for security or off-bike charging.
Owners frequently describe the M-66 R7 as “well-built”.
Owners praise Addmotor’s customer service.
A headlight and taillight with turn signals and brake activation are included.
The Promax stem offers 60 degrees of adjustment.
Metal fenders and a horn are part of the M-66 R7 package.
11 reasons not to buy
Only one frame size is available and testers say that the pedaling position is "uncomfortable," cramped, and unsuitable for riders above 6'.
The "harsh" acceleration may be overwhelming for some.
Buyers and experts say the heavy M-66 R7 is a strain to pedal unpowered.
Testers report a lag in pedal-assist engagement.
The M-66 R7 weighs a hefty 86lb.
A lack of instructions makes this bike hard to assemble for novices.
One reviewer has trouble setting up the mechanical disc brakes.
For one buyer, the suspension fork came loose on their first ride.
Critics say the M-66 R7’s fenders do not provide full splash cover.
The included rear light must be operated manually. It is not wired into the display.
An owner reported not receiving the adjustable stem that is pictured on the M-66 R7 product page.
The Addmotor M-66 R7 is a fat-tire, Class-2 moped-style e-bike with a 750W Bafang motor to haul considerable mass up to 25mph. This bike can carry a passenger, as long as the combined weight is under 300lb. With a 20Ah battery, the range is solid, but falls short of Addmotor's 105-mile max. Throttle-only range is roughly 30 miles on hilly terrain. Reviewers say that this bike has plenty of torque to carry two people at the bike’s speed threshold but that pedaling is uncomfortable and impractical, especially for taller riders. Given that, experts consider the M-66 R7 a good choice for comfy cruising on throttle power.
The Addmotor M-66 R7 is a moped-style e-bike powered by a 750W Bafang motor and 20Ah battery.
The bike’s quick acceleration and 25mph top speed make for an exciting ride. The geometry, mimicking a traditional moped, is comfortable and stable but not ideal for pedaling.
In this review, we’ll put the M-66 R7 through our standardized tests to see how it performs against the competition.
What Is the Addmotor M-66 R7?
This e-bike, powered by a 750W motor, would be easy to mistake for a regular moped. The long, padded seat and upright seated position make for a comfortable ride, but the trade-off of this geometry is a compromised ability to pedal. It seems Addmotor didn’t intend this bike for heavy pedaling.
So, how does it compare to other e-bikes, and are moped-style e-bikes a logical option for all users? Let’s dive into the pros and cons.
Powerful Motor and Throttle
The M-66 R7’s motor is powerful and responsive. Because of the uncomfortable pedaling position, the range test was primarily done on throttle power. Despite this, I maintained an average speed of 17.5mph for almost 30 miles. The throttle acceleration test results were also impressive, with the bike going from 0 to 20 in just eight seconds.
So, if you want a bike with solid throttle power and rapid acceleration, the M-66 R7 could be worth considering.
High-Speed Stability and Comfort
The M-66 R7 is stable and comfortable, even at speeds over 30mph. The bike’s high weight (86lb), wide tires, and upright seated position contribute to this stability and comfort.
Large Battery Capacity
The M-66 R7 runs on a 20Ah (960Wh) battery, one of the largest in this price range. This high capacity ensures good range when relying on the throttle.
During the range test, the battery discharged steadily and predictably, and the motor’s power was only affected when charge dropped below 10 percent. This predictability is crucial for reliably estimating range.
Harsh Acceleration
The M-66 R7’s acceleration is harsh. While this is okay for more experienced or thrill-seeking riders, many will find it overwhelming.
Quick acceleration is also handy when trying to keep ahead of traffic in a busy urban area, so whether or not this is a con is down to personal preference and experience.
Pedaling Position
The Addmotor M-66 R7 isn’t designed for comfortable pedaling. As a taller rider (6’0″), I found the position particularly uncomfortable. It quickly led to discomfort in my knees and hips, meaning I relied heavily on the throttle.
However, I did enjoy riding when using the throttle. The bike is comfortable when seated without pedaling, and thankfully, the powerful motor means you don’t need to pedal regularly.
High Weight
The M-66 R7 bike is large and heavy, weighing 86lb. This makes it difficult to lift, so buyers will need ground-floor storage and a specialized vehicle-mounted bike rack if they plan to transport it.
What Does It Do Best?
The M-66 R7 is a powerful e-bike with thrilling acceleration and speed. It’s stable, comfortable, easy to ride, and maintains high speeds using the throttle.
Those looking for a moped-style ride will undoubtedly enjoy it. Likewise, commuters wanting an effort-free, fast ride with a solid range of around 30 miles using the throttle and max pedal assist will appreciate the M-66 R7.
With its wide tires, suspension fork, and capable motor, the bike performs well on roads and light off-road trails. The stability and comfort translate to a surprisingly enjoyable ride on dirt or light gravel.
Reasons to Look Elsewhere?
The most important point about the M-66 R7 is that its riding style differs greatly from that of a traditional bike. I found the M-66 R7 particularly uncomfortable to pedal. Instead of pedaling, riders will likely rely on the throttle.
Potential buyers should also carefully consider the weight and size, which can be cumbersome in urban settings and limit the ability to store and transport the bike.
The bike has a wide turning radius, making it unwieldy in tight spaces. Additionally, riders over 6’0″ should look elsewhere, as it will be too cramped.
Conclusion
The Addmotor M-66 R7 is fast and exciting. Its powerful motor and easy-to-use throttle encourage speed. The bike is also comfortable and easy to ride, even at high speeds or off-road. Combined, this makes for a great riding experience that’s easy to love, as long as you don’t intend to pedal.
Again, the main downside is the uncomfortable pedaling position, which makes you dependent on the throttle. The size and weight are also worth considering, as storage, lifting, and transportation are more complicated.
Despite these drawbacks, the M-66 R7, with its vintage moped look, remains a solid option for fast throttle-powered rides on or off-road.
Specs
Electric Bike Class: Class 2 (with 25 mph max speed limit) Warranty: 1-2 year limited warranty (depending on the item) Battery Weight: 12lb Total Weight: Claimed: 74lb – Actual: 86lb Motor Brand: Bafang 750W Motor Type: Geared rear hub Motor Nominal Output: 750W Max Torque: 80Nm Battery: 48V – 20Ah Samsung cells Range Claimed: Up to 105 mi (assist level 1) Range Tested: 29.52 mi – 1,480 ft. – 17.5mph avg. Speed: Max 25mph Throttle: Half twist – left side Pedal Assist: 7 assist levels (adjustable from settings) Charger: 48V – 2A output charger Charge Time: 10 hours Display: LCD Frame: 6061 Aluminum Fork: Dual crown – 80mm travel Brake Levers: Tektro Aries mechanical lever Brake Calipers: Tektro Aries mechanical Brake Rotors: Tektro 180mm Crankset: Aluminum 170mm – 42t – double-sided guard Derailleur: Shimano Altus 7-speed Shifter: Shimano TX-50 7-speed Freewheel: Shimano 14-28t Rims: Cast alloy double-walled 20″ rims Tires: Kenda Krusade puncture-resistant 20″ x 4″ Fenders: Aluminum, front and rear Lights: 40-lumen headlight, rear light with brake signal, turn signals Grips: Faux-leather ergonomic Saddle: 2-person banana-style, 23.5″ x 8.5″ Handlebar: Adjustable, BMX-style Kickstand: Single-side Pedals: Welgo alloy platform pedals Max. Total Capacity: 300lb
Frame and Geometry
The M-66 R7 features a moped-inspired frame with a chair-like seated position. This straight-backed position can be fine-tuned using the adjustable stem with 60 degrees of movement.
The seat is long, heavily padded, and comfortable. However, it can’t be raised, and at 6′, I found the seated position very cramped and uncomfortable on longer rides.
The aluminum frame is strong and seems well-built, with no notable flex during testing.
The bike feels comfortable and relaxed at speed and performs reasonably well off-road despite its lack of rear suspension. The dual-crown 80mm suspension fork does a good job of nullifying bumps and the padded seat cushions rear impacts.
The 750W Bafang motor is capable of 1000W at peak output and offers a max torque of 80Nm, enough to get you to the top of most hills.
The controller is programmed to deliver a lot of torque immediately, meaning quick acceleration and an exciting ride. This is useful for commuters who want to keep up with traffic.
The powerful motor offsets the inefficient, uncomfortable pedaling position. Riders can rely mostly on throttle power to tackle hills and maintain high cruising speeds.
Cockpit and Control
The M-66 R7 features an array of buttons labeled with icons. The control panel on the left bar operates the center-mounted display. It has up and down buttons, a power/options button, and buttons for the left and right turn signal and horn.
On the right side, you have the throttle and a small black button to turn it on and off, so if you have an issue with your throttle, look here first.
The cockpit also features an adjustable stem with 60 degrees of movement.
Battery
The M-66 R7 is powered by a large 48V 20Ah externally mounted battery. The battery must be turned on before the bike can be activated.
The battery is mounted below the seat and is a little challenging to remove. After unlocking it with the key, you must give it a good tug upward to remove it from the track. Lining it up against the plastic rails when reinserting can also be tricky.
The battery has Samsung cells and takes up to 10 hours to fully charge from the 2A charger. Charging can be done on or off the bike via the charge port located on the side of the battery. When not in use, the charge port is protected by a small cover.
Drivetrain
I didn’t enjoy pedaling this bike, mostly due to the uncomfortable pedaling position. However, the gearing is also insufficient for riding at the bike’s top speed.
With a 14-28t cassette, you experience ghost pedaling at speeds over 20mph, leaving you dependent on the throttle.
At the opposite end of the spectrum, the bike is a chore to pedal when not under power. Its heavy weight and difficult seating position lead to a less-than-ideal pedal experience.
The drivetrain uses a Tourney 7-speed overhand TX-50 shifter and a 14-28T cassette. The overhand shifter offers a visual indicator for gearing. But I find it to be clunky during use. It would be great to see an increased gear range on this bike.
The Tektro Aries mechanical disk brakes performed excellently in our braking tests. Hydraulic brakes generally offer better stopping power than mechanical brakes, but this brakeset returned similar results to the hydraulic brakes found on competing bikes. However, the brakes make a lot of noise.
Wheels, Tires
The M-66 R7 has 20″ x 4″ Kenda off-road tires with medium tread. These offer good traction and comfort on pavement and dirt paths but tend to drift on gravel or loose surfaces.
The M-66 R7 has cast alloy wheels, which require less maintenance than spoked wheels. Overall, the wheels and tires add to the bike’s stability and comfort, inspiring confidence at speed.
Safety
Addmotor includes a bright headlight and an integrated taillight with brake activation, turn signals, and hazard lights.
The throttle has an on/off switch, so you can deactivate it and avoid accidentally engaging it. The bike also has a motor inhibitor switch to aid stopping.
Kickstand
The Addmotor has a standard single-sided kickstand.
Contact Points
Grips
The M-66 R7 has ergonomic faux-leather grips, which don’t lock on, meaning they can slide on the bars. Personally, I’d prefer a set of rubber lock-on grips for this bike.
Saddle
This bike has a well-padded seat that is long enough to fit a passenger. Unfortunately, it’s not adjustable, and it was too low for me, resulting in a cramped, uncomfortable pedaling position.
However, the plush seat is comfortable when riding the throttle, remaining so throughout the range test. It even absorbs some of the rear impacts when riding off-road.
Pedals
Finally, the M-66 R7 comes with standard alloy platform pedals from Wellgo. These offer reasonable traction for most shoes.
The MOTAN M-66 R7 is a powerful, fast, and fun moped-style electric bike complete with passenger footpegs and a tool-free adjustable stem that makes it a breeze to adjust for riding with two people. Heavy and difficult to maneuver, the frame geometry makes for difficult pedaling, especially for tall riders.
This isn’t a serious all-terrain vehicle. Instead, it’s an awesome street bike. It’s not optimized for pedaling since you can’t adjust the seat. The claimed range is a joke – you’ll never see that unless you actually keep it in pedal assist level 1 all the time. It’s quick, fun, and comfortable to ride, thanks to that plush seat.
This is a moped style electric bike that is super fun to just cruise around on without even pedaling… a bit slower than other Bafang 750-watt motors we’ve tested… So, it seems like Addmotor may have custom-wound this motor for better hill climbing and acceleration.
We have this long, wide banana seat that can comfortably accommodate two riders easily and I’m actually surprised that with only a 750W geared motor and an extra person’s load, it rides and accelerates without any struggle. For pedaling, it’s not the most ideal position since the seat is not height adjustable. I personally have not seen any difference between the first level and the max/fifth level on this bike. I find this model performing above the average.
I had a slight problem with this bike. When I rode it for a few miles I discovered that these bolts that are holding on the stanchions for the fork were very loose.
I contacted Addmotor and asked them to send me instructions on how to fix this issue, and I did a video on the first instructions which they sent me which did not work, so they sent me a second set of instructions… The truth is they got back very fast and they sent me the video very fast and it did fix the problem very effectively.
