We have read all expert and user reviews on the Addmotor M-81. In summary, this is what cyclists think.
17 reasons to buy
- The M-81 rocks a long and hefty rack with a 55 lb carrying capacity.
- A 48V 20Ah battery will see you over as many as 80 miles from one charge.
- A reviewer rode 21mi on throttle-only. ½ of the bike’s battery remained.
- Addmotor’s 750W motor will propel the M-81 to 907W of peak power.
- 7 levels of pedal-assist provide nuanced support across varying gradients.
- Fatty Kenda Gigas 4” tires wrap around 20” wheels for all-surface comfort.
- Disc brakes are hydraulic and use 180mm rotors, to stop the M-81 with vigor.
- Bumps are trumped by 100mm of spring-suspension in the front fork.
- A super-low-step frame makes it easy to get on and off the M-81.
- The M-81 comes in 4 colors, but ‘Army Green’ is particularly popular.
- The M-81's 7-speed Shimano drivetrain spans a decent gear range.
- An adjustable stem allows the M-81 to adapt to a range of rider heights.
- Assembly took one tester 25 minutes. Tools are provided.
- The M-81 features integrated front & rear lights, including turn signals.
- A comprehensive and clear display shows all required e-bike metrics.
- There is a handle on the M-81’s saddle, to help lift the bike.
- An M-81 reviewer is impressed by the bike’s “clean” cable management.
3 reasons not to buy
- The M-81 is only available in one frame size, to suit riders 5’4” to 5’9”.
- The front suspension fork’s 100mm of travel isn’t suited to rocky terrain.
- Faux-leather grips are wider than the bike’s throttle and look cheesy.
The Addmotor M-81 is a versatile rig that would make for a great family vehicle or delivery bike. With a long rack, owners can seat two small children (with or without safety seats) or lug a hotbox of take-out across the CBD. It features a substantial 48V 20Ah battery. Addmotor says it will carry you for as much as 80 miles on a charge. One reviewer rode 21 miles using only throttle and still had half the bike’s battery bars remaining (on-screen at least).Unfortunately, recommended rider height tops out at 5’9” but fortunately, it has a super-accesible low-step frame that suits shorter riders, senior riders and the stop-start nature of inner-city errand-running and work-a-day delivery. It has hydraulic brakes, integrated lights and a little front suspension. Addmotor does not list the M-81’s weight but it’s somewhere between 71lb and 80lb.
93/100 based on 1 rated expert reviewAddmotor M-81 Cargo E-bike (Assembly/Review)
1 day ago
