How to Adjust Cantilever Brakes
Adjust brake levers, re-surface pads, set cable tension and center cantilever style brakes.
In today’s tutorial I’ll demonstrate how to adjust cantilever style brakes. I will cover linear pull, or V-brakes in a future tutorial. For this job you’ll usually need a 5mm allen key, a 10mm open-end wrench, a strip of sandpaper, and an optional cable puller.
Adjust Levers
The first step is to set up your brake levers. Start by loosening the clamp and then align the levers so that they match the angle of your arms when you’re riding. Once the angle is set, tighten the clamp.
If you have smaller hands and your levers are hard to reach, you can set them closer by tightening the reach adjustment screw on the inside of most levers.
Check Wheel Center
Before you begin, you should also check to make sure your wheel is properly centered in the frame, as this will affect the position of your brake pads. Make sure the axle is securely fastened all the way up in your dropouts. If the wheel is still off-center you may need to check the dish, which is further explained in the previous wheel truing tutorial.
Set up Brake Pads
Now loosen the tightening bolt on your brake arm and tighten the lever’s barrel adjuster all the way.
Loosen and then remove both brake pads from their mounting posts and inspect both their surfaces to make sure they are not too worn. If you see any metal poking through the pad surface, you’ll need to replace them. If the pads are in good shape, it’s a good idea to resurface them using some sandpaper.
With the pads removed, adjust the brake cable until both brake arms are parallel straight up and down, and then tighten. Using a cable puller makes brake cable adjustments a lot easier.
Now reinstall the brake pads and align them so the pad face is flat against the rim. Then tighten the pad so that it’s snug, but still loose enough to move around.
Take a look from the side to make sure the pad is in line with the rim’s brake surface, and not touching the tire or hanging off the bottom of the rim. If you can’t avoid one or the other happening, your pads may be too wide for your rim, and you’ll have to find some narrower pads.
Cantilever brake pads should be set so that the front of the pad touches the rim before the rear when you pull the brakes. This is called ‘toe-in’, and it prevents squealing when you use them. It’s a bit tricky to set up, so you may have to re-tighten the pads several times before it is correct.
For proper toe-in adjustment, there should be a gap of a few millimeters at the rear of the pad when the front is touching the rim. Park Tools recommends temporarily wrapping a rubber band around the back end of the pad to help set the spacing. Don’t forget to remove it when you’re done adjusting the pads.
Adjust Cable Tension
Some bikes like mine have a link unit that sets the straddle wire position for you. If you’re using a carrier style with a pinch bolt, make sure the carrier is tightened as low as possible, while still providing enough clearance for your crossover cable, tire and fenders.
Now adjust the cable tension on the brake arm by pulling the cable through the pinch bolt and tightening. You’ll have to play with this adjustment until your brakes feel good. I like to have mine set so that the pads hit the rim when my lever is pulled about 1/4 of the way.
Make sure both pads now have equal clearance, and are not rubbing against the rim.
Centering
For minor centering adjustments, there is usually a screw on the left brake arm that sets the spring tension on one side. Tighten this clockwise to pull the pad away from the rim, and counter-clockwise to set the right pad closer to the rim.
Related Links
- Park Tool: Cantilever Brake Service
- Sheldon Brown: Adjusting Cantilever Brakes
Recommended Tools
- Hozan 4th Hand Cable Puller
- Park Tool HXS-1.2 Hex Wrench Set
- Park Tool Wrench Combo Set
- Park Tool SD-Set Shop Screwdrivers
Categories
Latest post 30 mins agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 4 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 4 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Read moreTrek domane tyre
Read more
