How to Choose Basic Bike Repair Tools
An overview of the tools needed to perform basic maintenance and minor repairs at home.
Video updates
- 00:30 - You can also use a car bike rack to hold up your bike!
Today we’ll learn about some tools that every home repair shop should have in order to perform basic adjustment and maintenance procedures. I’ll cover more advanced tools in a future tutorial.
Repair Stand
The most important tool in any home shop is a repair stand. Park Tools makes an economy stand called the PCS-9 that will do the job, but if you’re going to be working on bikes regularly I’d recommend the PCS-4 because of the superior clamping system. If you’re not ready to invest you can always hang your bike from the ceiling, and for minor adjustments you can also use a bike display stand to keep your rear wheel off the ground. If you’re adventurous you can always build your own stand.
Cleaning Supplies
For basic cleaning you should have some cleaning solvent and a supply of rags. I find the Park gear cleaning brush extra handy for cleaning grime out of your sprockets and chain.
Lubricants
You should have 3 basic types of lubrication: chain oil, light oil and waterproof grease. See the video on choosing the right lubricants.
Screwdrivers
Both flathead and phillips (+) screwdrivers are essential.
Pliers
For pliers you should have a good set of wire cutters for trimming inner cable ends. The 4th hand tool is also invaluable for adjusting brake and derailleur tension and attaching zip-ties. If you plan on replacing cable housings, a proper cable cutter makes a clean cut every time.
Hex Wrenches
Most of the components on modern bikes are fastened using 4mm, 5mm or 6mm allen bolts. One of my favorite tools is the Park triple hex wrench, which includes all three basic sizes. I also find it useful to have a set of long allen keys on hand, as they include some extra sizes like an 8mm for crank bolts, and a ball-end that makes it easy to quickly spin long bolts.
Wrenches
For wrenches, most components are between the sizes of 8mm to 17mm, so having a good set of open-end wrenches is a must. It’s also a good idea to have a couple of adjustable wrenches on hand for odd jobs, but I recommend using the proper size whenever possible as adjustable wrenches often slip and can damage your bolts.
Wrenches for Pedals, Headsets & Hubs
A 15mm pedal wrench is necessary for tightening or replacing pedals. They come with a long handle which helps loosen pedals that are often very tight. If you have an older threaded headset you should have either a 32mm or 36mm headset wrench for making adjustments. A set of 13&15mm cone wrenches are also often needed to adjust your front and rear hubs.
Tire & Tube Tools
For tire repairs you’ll need a set of plastic tire levers. Never use a screwdriver or metal tool to pry off your tires as you’ll run the risk of pinching your tube or damaging your rim. For installing very tight tires I recommend the Kool Stop tire jack, which makes it really easy to pull them on. Of course every home mechanic should also have an air pump, tire guage and if you have presta valves, a presta valve adapter.
Wheel Tools
The last thing you should have are some basic wheel truing tools. Spoke wrenches come in 3 common sizes which you can get individually, or as a combination tool like the one from Park. You can usually make minor wheel adjustments on your bike using your brake pads as a guide, but if you want to be more precise you’ll need a truing stand. Park makes a great economy stand called the TS-8, but if you’re looking for a shop-quality stand that will last a lifetime, it’s worth investing in the TS-2. Once you’ve invested in these tools, you’ll be ready to tune up your bike and take care of minor repairs yourself!
Related Links
Categories
Latest post 6 days agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 1 week agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 1 month agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoCurrently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read moreTrek domane tyre
Latest post 6 months agoRecently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
