important: Nuts and bolts on your bike should always be tightened to the manufacturer's specifications.
How to Bleed Tektro Auriga Comp Disc Brakes
Learn how to bleed the air out of Tektro Auriga Comp hydraulic disc brakes.
In this tutorial we’ll learn how to bleed the hydraulic brake system on Tektro Auriga Comp Disc Brakes. You should always bleed the system after shortening or replacing the hose, or if you have opened the system to air at any time. If your brake action feels spongy, bleeding the system will also improve performance.
What You’ll Need
For this job you will need a 2, 3 and 4mm allen wrench, a 7mm open end wrench, a T15 Torx wrench, a piston holder or 10mm allen wrench in order to keep the pistons in place, a small bag and elastic band, and a clean rag. You will also need a Tektro hydraulic disc brake service kit, which should include a syringe, 2 lengths of plastic tubing, an outlet valve, and a bottle of Tektro hydraulic brake fluid (mineral oil). Make sure to use the specific type of oil for this brand, as using other types could damage your system. A repair stand and clean work space are also highly recommended.
Mount your bike in the repair stand, making sure the wheel axles are parallel with the floor. Now remove your wheel. Remove the disc brake pads and slide a piston block or 10mm allen wrench into the gap to keep the pistons in place.
Remove the rubber cover from the bleed outlet valve on the brake caliper. Attach the smaller tube from your service kit onto the syringe and fill your syringe about halfway with oil. Now firmly insert the syringe and tube onto the bleed outlet valve.
Using your 4mm allen wrench, slightly loosen the brake lever bracket until it rotates on the handlebar. Loosen and move the shifter out of the way if needed. Rotate the brake lever so that the top of the reservoir tank is parallel with the ground.
Using your T15 Torx wrench, loosen and remove the bolt on top of the reservoir tank, and thread the outlet valve into the hole, with the longer plastic tube firmly attached and place the other end into your plastic bag and keep it in place with an elastic band.
Now open the outlet valve on the caliper slightly 1/8 to 1/4 turn. Using the syringe, push and pull the oil back and forth through the system several times until there are no more air bubbles coming out of either end. Now tighten the bleed valve with your 7mm spanner to 4-6Nm.
Remove the hose and reinstall the rubber outlet valve cover. Now remove the outlet valve from the reservoir and reinstall the bolt using your T15 Torx wrench. Tighten this bolt to 2-4Nm.
Use a clean rag to wipe any excess oil off the lever, caliper, and hose. Reinstall your brake pads and front wheel. Depress the brake lever a few times, to ensure the action feels stiff and not spongy.
In our next tutorial we will take a more in-depth look at replacing and adjusting the brake pads on this model.
Related Links
Recommended Tools
Categories
I live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read more
Rear v-brake repair
Latest post 2 weeks ago
Hi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Read more
Custom Bike part manufacturing
Latest post 1 month ago
Hello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Read more
I have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down.   IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51)   IMG_20250122_105428.jpg (...
Read more
Hi everyone! I hope you're enjoying a great start to 2023. I'm curious to hear your go-to method for getting a chain truly clean. I don't mean, just looks shiny or is good enough for a quick clean after a ride. I want to know what you do when you want to get every last morsel of ground-up, link-destroying, roller-eating, tooth-gnashing crud out of your chain. The Best Chain-Cleaning Recipe Ever?...
Read more
What jockey wheel Red 10 Speed
Latest post 2 months ago
Can anyone advise what type of replacement jockey wheel I need for a 10 speed Red rear mech (it's got 11 teeth)? Bonus points if it's a link to a cheap (ish) one! Thanks...
Read more
Grip Shifters
Latest post 3 months ago
Currently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Read more
9 speed chain on 8 speed bike
All of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read more
Operation of Santa Monica Ebike
Hello - new owner with an How to Operate the bike question. Hopefully, this is easily answered I Bought this bike a few weeks ago - Tested many bikes and finally landed on this particular Santa Monica. However, got busy with Christmas shopping, Life, and not so great weather days distracted me from riding. I also test drove so many that I forgot how to operate it.... I "thought" I remembered, ...
Read more
Gears and derailleur misalignment
Latest post 4 months ago
  My Trike.jpg (Size: 57.65 KB / Downloads: 50)   Wife Trike.jpg (Size: 60.74 KB / Downloads: 50) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Read more
I'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Read more
Shifting is almost impossible
My wife's road bike has Shimano Sora shifters with a triple front derailleur (stock). The thumb switch on the front shifter is VERY hard to use and she can't do it when she's riding. I did a full adjustment of the front derailleur but it didn't change anything. One thing that I noticed is that the shifter works smoothly when the shifter cable is unattached from the derailleur, suggesting that the ...
Read more
7-speed bicycle with bent rim
Latest post 5 months ago
I recently bought a 7-speed bicycle practically brand new it still has a little rubber nipples on the tires apparently it got backed into in the garage and it bent the rear rim sideways my question is can I go out and buy another just like single speed 20 inch bicycle and put the 7-speed cassette onto that rim?...
Read more
Trek domane tyre
Hi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read more
Schwinn meridian rear drive axle
Latest post 6 months ago
Recently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
