How to Overhaul a Bottom Bracket
How to disassemble, re-grease, reassemble and adjust a cup and cone bottom bracket.
Video updates
- 02:22 - IMPORTANT: Apply a thin layer of grease to the threads before inserting into the frame.
Today we’ll learn how to overhaul and re-grease an adjustable bottom bracket. To remove the cranks you’ll need a crank puller, a 17mm open end wrench and a large adjustable wrench. To overhaul the bottom bracket you’ll need a bottom bracket wrench or a pin spanner, a hooked lock ring wrench, and a 36mm wrench. For re-greasing the bearings you’ll need some cleaning solvent and waterproof grease, a rag, a toothbrush and a small container to clean the bearing cages.
Disassemble
Begin by removing the cranks. Watch the cotterless crank removal tutorial for a more detailed procedure. Once the cranks are removed, loosen and remove the lock ring on the non-drive or left side of the bike by turning counter-clockwise. Once the lockring is removed you should be able to easily loosen and un-thread the bearing race using either a pin spanner or a bottom bracket wrench.
Now pull the spindle and both bearing cages out of the frame. It’s important to remember which way the spindle came out, as they are directional. The drive side usually has a longer distance from the bearing race to the end of the threads. Wipe off the bearing cages, drop them into the solvent, and let them soak while you use your rag to clean the spindle and both outer bearing races.
Tighten the drive-side bearing race by turning it counter-clockwise with your 36mm wrench. Unless you are replacing the bottom bracket, there is no need to remove it.
Inspect
Shine a flashlight into your bottom bracket shell to inspect the bearing race for pitting and wear. Inspect your other bearing race and then carefully inspect the spindle. Most wear occurs on the spindle’s bearing races. If you see pitting here you should take it to your local bike shop for a replacement.
Clean
Now clean both bearing cages with a toothbrush and solvent, and then set them aside to air-dry. These should also be replaced if they are worn or have bent cages.
Grease
Apply a layer of grease on both bearing races and cages. A grease gun makes it easy to squirt grease inside the gaps between the bearings. Then place the bearing cages into both races. The rounded side of the cage should be facing down into the bearing race. Seal them in with another layer of grease.
Reassemble
Now insert the spindle the same way you removed it. Wipe off any excess grease that comes out on the spindle. Grease the threads inside the bottom bracket shell, and then slide the outer race and bearing cage onto the spindle. Thread it on all the way clockwise but don’t tighten it. Again you’ll need to wipe off excess grease.
Adjust
Thread on the lock ring finger-tight. Before adjusting the bottom bracket, first install the drive-side crank arm and tighten it as shown in the crank installation tutorial. This will help us make a proper adjustment. Now hold the inner race firmly with your wrench or spanner and tighten the lock ring. When properly adjusted the spindle should spin smoothly. If it doesn’t, you’ll have to loosen the lock ring, back off the inner race a little bit, and then tighten it again.
Check for play by placing the crank arm close the frame and pushing and pulling it against the frame. There should be no movement. If it feels loose, you’ll have to loosen the lock ring, tighten the inner race a little bit, and then tighten the lock ring again. When the adjustment is correct, install and tighten the left crank arm and you’re done!
Related Links
Recommended Tools
- Park Tool Park HCW-11 Adjustable Cup Wrench
- Hozan C-205 Lockring Tool
- Super Lube White Grease Tube
- Finish Line Grease Gun
- Shimano TL-FC10 Crank Extractor
- Park Tool CCW-5 Crank Wrench
Categories
Latest post 6 days agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 2 weeks agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 1 month agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoCurrently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Latest post 4 months agoMy Trike.jpg (Size: 57.65 KB / Downloads: 50) Wife Trike.jpg (Size: 60.74 KB / Downloads: 50) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Latest post 4 months agoI'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Read moreTrek domane tyre
Latest post 6 months agoRecently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
