How to Replace a Broken Spoke
Demonstrates a single spoke removal and installation.
If you break a spoke on your wheel, the best thing to do is stop riding until you can get it repaired. However, sometimes you simply have to keep riding, in which case you can keep the broken spoke out of the way by twisting it around an adjacent spoke.
Spoke Removal
To replace the damaged spoke, first remove your wheel and then the tire, tube and rim tape. Then remove both ends of the damaged spoke and nipple. Spokes usually break either at the nipple or at the hub flange. If it’s a rear wheel, you’ll have to remove the cassette or freewheel first.
Spoke Installation
Insert the new spoke and gently flex it into place, using the other spokes as a guide. When installed properly, the spoke pattern should be consistent all the way around the wheel.
I personally recommend using linseed oil to lubricate the nipple threads before threading the nipple on to the spoke using a screwdriver or nipple driver.
Gently pre-bend the new spoke by pushing down on it at the hub flange, and then tighten the nipple using a spoke wrench until it has the same tension as the rest of the wheel. Check this by plucking the middle of the other spokes on the same side and then compare them to the sound of the new spoke. Now you can true the wheel as demonstrated in the last tutorial, and re-install your rim tape and tire.
Related Links
- Bike Hacks: 7 DIY Truing Stands
- Jim Langley: Wheelbuilding
- Park Tool: Wheel and Rim Truing
- Park Tool: Wheel Tension Measurement
- Sheldon Brown: Truing Wheels
Recommended Tools
- Park Tool SW Spoke Wrenches
- Park Tool SW-7 Triple Spoke Wrench
- Park Tool SBC-1 Spoke, Bearing, and Cotter Gauge
- Park Tool TM-1 Spoke Tension Meter
- Park Tool TS-8 Home Truing Stand
- Park Tool TS-2.2 Home Truing Stand
Categories
Latest post 5 days agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 1 week agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 1 month agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoCurrently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read moreTrek domane tyre
Latest post 6 months agoRecently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
