We earn affiliate commission.
Learn more
Type
32.4, 32.1, 31 lb
We have read all expert and user reviews on the Cannondale Cujo 1. In summary, this is what cyclists think.
11 reasons to buy
- Riders felt the ride and seating position atop this steed were comfortable.
- Mounts are attached for a 2x derailleur, two bottle-cages and a rear rack.
- A TransX dropper post is included and internally routed on the Cujo.
- The Cannondale C3 bar was wide enough to throw the Cujo around.
- The 11 speed drivetrain provided an ample gear range for trail use.
- The Cujo represents great value with frugal componentry choices.
- WTB Ranger tires offered excellent traction on crumbly climbs.
- The 120mm Rockshox Recon fork was responsive and supple.
- Shimano M425 Hydraulic Discs were resilient and capable.
- The XT rear derailleur and XLS shifter worked soundly.
- The bold ‘Acid Red’ color was complimented.
- The bottom-bracket is low, leading some to experience pedal scrape.
- One owner described the ‘Acid Red’ color as being “...a bit hard on the eyes”.
- An expert felt the OEM Cannondale Platform pedals lacked grip.
- Seat and chainstays provide plenty of clearance for plus-size tires.
- Quick-release hubs with boost-spacing are eccentric and make replacements challenging.
- Some riders felt movement in the dropper-post, which failed within hours for one rider.
Cujo’s geometry sits somewhere between gentle cross-country angles and rowdier trail-riding. This geometry, in concert with 2.8 inch plus-size tires, reportedly leads to able climbing. However, one expert felt that big rubber and steeper geometry led to a bouncy, somewhat sketchy ride on chunky descents. It was felt that a shorter wheelbase contributed to a less stable ride. Economical components have been chosen in less significant areas, keeping prices down. In summary, the Cujo is a good choice for entry-level trail-riders who want something that can stand up to the abuse that beginners demand.Expert Reviews
60/100 based on 1 rated expert reviewCannondale Cujo 1 Review
Best Mountain Bikes
Cannondale Cujo 1 in comparison to averages
3 hours ago
4 hours ago
4 hours ago
