Cannondale Moterra LT
76/100
6 Hours
60 Miles
85 Nm
36V 20.1Ah
57.3, 58.7 lb
We have read all expert and user reviews on the Cannondale Moterra LT. In summary, this is what cyclists think.
13 reasons to buy
  • The Moterra LT comes in two builds: the Carbon 2 and the higher-end Carbon 1.
  • Testers credit the mullet wheels and geometry for creating a stable and comfortable ride.
  • The Bosch Performance Line CX motor impresses experts with its smooth power and speed.
  • Experts appreciate how the balanced riding position inspires confidence on descents and smooth climbs.
  • Testers find that the Moterra LT’s low center of gravity improves handling.
  • Experts praise the supple initial touch and overall support and composure of the Moterra LT’s rear end.
  • Torque caps on the front axle improve front-end stiffness.
  • Testers laud the traction provided by the 2.6” Maxxis tires and well-tuned rear suspension.
  • In a max pedal assist range test, a reviewer covers 29.8 miles with 5,479 feet of elevation gain.
  • The four riding modes can be customized via the Bosch app.
  • Reviewers value the inclusion of a skid plate, mudguards, and rubber frame protectors.
  • An expert finds the Cannondale DownLow dropper seatpost is smooth and easy to use.
  • The SRAM Code RSC brakes (Carbon 1) prove powerful and reliable in testing.
  • All expert testers say the Moterra LT’s high weight negatively impacts handling, and the long rear end reduces agility.
  • A reviewer feels the kickstand mount and keyed battery are unnecessary on a true enduro bike.
  • The cables route through the angled stem, so swapping stems or changing stem height is complicated.
  • An expert says the RockShox Zeb Select fork’s primitive damper (Carbon 2) means it lacks control on big hits.
  • The Moterra LT’s weight, high bottom bracket, and long chainstays limit its maneuverability in technical terrain and tight turns.
  • Testers note that fine-tuning the coil rear shock or changing the spring is more complicated than with air shocks.
  • Some reviewers find the display controls bulky and overly complicated.
The Cannondale Moterra LT is a Bosch-equipped electric enduro bike with 170mm front and 165mm rear travel. It comes in two builds, Carbon 1 and Carbon 2. The front triangle is carbon, but the rear swingarm is alloy. The Moterra LT earns praise for its comfortable, stable ride, long battery range, well-tuned suspension, and impressive all-round performance. However, the high weight and geometry limit its capabilities in technical terrain. Other complaints include the Carbon 2’s low-end suspension fork, tricky stem swapping and adjustment, and unnecessarily complicated controls. The Moterra LT isn’t the agile e-MTB Cannondale claims, but its stability on rough terrain will appeal to many, though it’s expensive.
76/100 based on 3 rated expert reviews
Mountain Bike Rider
The Cannondale Moterra Neo Carbon LT 2 Electric Mountain Bike Review
At the discounted price, the Cannondale Moterra LT is a seriously attractive proposition…
Cannondale Moterra Neo Carbon LT 2 Review
The Cannondale Moterra Neo Carbon LT2 has proven to be a lot of fun on the trail and a great all-rounder once set up correctly.
E-MOUNTAINBIKE
The Cannondale Moterra Neo Carbon LT 1 – In Our Huge “Best E-Mountain Bike of 2023 Group Test”
While the spec sheet suggests a massive downhill potential, the Moterra doesn’t deliver the performance you expect on the trail. As a result, the Cannondale struggles to keep up with the fun factor of the more agile bikes in this test.
The Loam Wolf
2023 E-MTB Shootout Cannondale Moterra Neo LT 2
While we didn’t really have any major criticisms on how it rode or areas where we didn’t like it, it also didn’t have us jumping off with a huge smile or proclaiming how awesome it was…
Best Day Ever MTB
Cannondale Moterra Neo Carbon Review
… the suspension’s great, brakes are good, handling is good, [it] feels nice and stable…
Up Hill Will
Unleashing the Beast: Cannondale Moterra LT Electric Mountain Bike Review!
… it is made for the hardcore stuff, and let me tell you what, it ate the chunk up like it wasn’t there.
brujulabike
We Test the Cannondale Moterra Neo Carbon LT 2: Pure Power
This does not make the uphill climbs uncomfortable or heavy, since we have the assistance of the Bosch motor and a modern geometry that positions us optimally. And it is heavier than most, but we were surprised by its handling…
Test Cannondale Moterra Neo Carbon LT 2 Analysis Review [Spanish]
Overall, I loved the handling and the responsiveness…
DoleKOPCOM
Test: Cannondale Moterra Neo Carbon LT 2 – Bike Park E-Bike [Czech]
By the way, Moterra Neo Carbon LT 2 in the tested setup is not extra light, despite the carbon frame, [58.86lb] in total. The weight is, in my opinion, the only weak point of an otherwise great bike.
EMTB-News.de
Cannondale Moterra Neo Carbon LT 2 Test [German]
The e-bike impresses with its well-thought-out equipment, many clever details, and high-quality workmanship, as is typical for Cannondale. The only thing you have to get used to is the high weight.
90/100 based on 4 ratings
    75%
    25%
#115 Best Mountain
Bottom 10%
#31 Best Enduro
Bottom 20%
#26 Best Cannondale Bike
Bottom 20%
#713 Best of All Bikes
Bottom 20%
Cannondale Moterra LT in comparison to averages
