How to Clean and Lubricate a Chain
Frequent chain cleaning and lubrication will help keep dirt off your chain and prevent wear.
Regular cleaning and lubrication of your chain will help prevent your drivetrain from wearing out. You should clean and lubricate the chain when it is dirty, dry or begins to sound noisy. If you ride every day, you should clean and lube the chain at least once a month.
Chain Lubricants
I don’t recommend using either motor oil or 3in1 oil to lubricate the chain. Motor oil is too heavy and won’t fully penetrate the rollers, and 3in1 oil is vegetable based and will gum up the chain. I also don’t recommend using wax lubricants because while they don’t collect as much dirt, they are a lot of hassle to apply correctly, and wax is simply not as good a lubricant as oil. I do recommend mineral based chain oils like Finish Line Cross Country or Phil Wood Tenacious Oil because they do the best job of fighting corrosion and don’t wash away when they get wet.
Chain Cleaning
For cleaning, first shift the chain into the smallest sprocket on the rear. For average dust and dirt, wipe the chain clean with a solvent soaked rag. The easiest way to do this is to hold the chain still at the rear derailleur cage while firmly wiping the lower run of the chain. Then move the chain backward and wipe again until you’ve wiped the entire length of chain. Wipe between the rear sprockets using either a rag or a sprocket cleaning tool. Then clean all of the front chainrings on both sides.
Chain Lubrication
Shift your gears into the middle sprocket both front and rear. Remember that oil does a good job of spreading itself, so try not to over-apply the lubricant. Lubricate the inner circumference of the chain, on the side that faces the sprockets along the top of the lower run of the chain. Run the chain backwards while dropping oil down both sides of the rollers.
Shift through all of the gears to spread the lubricant evenly through the drivetrain. Then use a rag to wipe off any excess oil.
Related Links
- Jim Langley: Cleaning Your Drivetrain
- Park Tool: Chain Cleaning
- Sheldon Brown: Chain Maintenance
Recommended Tools
- Park Tool CB-4 Bio ChainBrite
- Park Tool CG-2 Chain Gang Chain Cleaning System
- Finish Line Wet Chain Lube (Cross Country)
- Phil Wood Tenacious Oil
- Park Tool CC-3.2 Chain Checker
- Park Tool CC-2 Chain Checker
Categories
Rear v-brake repair
Latest post 2 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 3 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 49) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoMy Trike.jpg (Size: 57.65 KB / Downloads: 49) Wife Trike.jpg (Size: 60.74 KB / Downloads: 49) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Read moreTrek domane tyre
Read moreBianchi Oltre Pro Garmin Mount
Latest post 6 months agoI am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
