How to Use a Chain Tool to Break a Chain
How a chain tool works, and how to use it to disconnect and reconnect your bike chain.
This week we’ll learn how to break a chain using a chain tool. I’ll cover the quick release method next week.
Quick Release Links
The first thing to do is check to make sure your chain does not already have a quick release link. Do this by turning your pedals backwards and carefully watching every chain link as it goes by. A quick release link will stand out as they look different from all of the others. If you find one, you can refer to next week’s tutorial for removal and installation instructions.
The Chain Tool
If you can’t find a quick release link, then your chain probably doesn’t have one. This has traditionally been the most common type of chain, and it requires a chain tool for both removal and installation.
Turn the handle of your chain tool counter-clockwise until the pin has backed off enough so you can place one of your chain links on the outermost slot, furthest from the handle. There are two places on chain tools where you can place a chain. The outer slot is for disconnecting and re-connecting the chain, while the inner slot is for loosening chain links.
Disconnect the Chain
Now tighten the handle clockwise until the chain tool’s pin connects with the end of your chain pin. Continue tightening the handle and you’ll see the chain pin get pushed into the link and start coming out the other side. The tricky part here is to push the chain pin far enough so that it is gets about halfway through the first of the two outer chain plates. If the chain pin gets pushed all the way out of the chain there is really no way to get it back in, and you’ll be forced to shorten or replace your chain.
One way to prevent this is to pay careful attention to how easy the handle turns as you push the pin through. When you get close to the end, you’ll feel resistance and the handle will become a slight bit harder to turn. As soon as you feel this, stop tightening the handle, and then give it another half a turn. This is usually the perfect spot to disconnect the chain. When you take the chain tool off, you’ll notice the chain is still barely held together, but can be easily disconnected by twisting and pulling the chain.
Reconnect the Chain
Notice how a tiny bit of the pin is still poking out of the inner side of the outermost plate. This is perfect, as it will help us re-install the chain. Twist and push the links back together until the chain pin clicks back into the inner link, once again holding the chain together.
Now back off the chain tool’s handle and place the chain back onto the same outer slot of the chain tool. This time position it so the protruding chain pin faces inward toward the chain tool’s pin. Now tighten the handle until the tool pin starts pushing the chain pin back through the link. Continue tightening until a tiny bit of the link pokes through the other side. Now take a look at both sides of the link… the chain pin should stick out roughly the same amount on either side.
Loosen the Chain Link
The process of re-connecting the chain caused the chain links to compress together, making a stiff link. To fix this, we use the inner slot on the chain tool. Back off the chain tool all of the way so that you can place the freshly connected link into the inner slot. Now tighten the chain tool’s pin until it connects with the chain pin and tighten it just barely, about a quarter of a turn. This usually loosens the chain link plates enough. Remove the chain from the tool and check to make sure the link is loose. If it’s still tight, try loosening it with the chain tool another quarter of a turn.
Related Links
Recommended Tools
- Park Tool CT-5 Chain Tool
- Park Tool CT-3 Chain Tool
- Park Tool CC-3.2 Chain Checker
- Park Tool CC-2 Chain Checker
Categories
Latest post 7 hours agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 5 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 4 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Read moreTrek domane tyre
Read more
