We have read all expert and user reviews on the Delta Cycle Heavy Duty Single Bike Wall Mount. In summary, this is what cyclists think.
5 reasons to buy
- Long-term owners deem the Heavy Duty Single Bike Wall Mount durable, citing the solid welds.
- The mount is quick and easy to install.
- Owners say bikes are stable when mounted.
- Reviewers appreciate the versatility, fitting most regular bikes.
- Testers say this hook is an affordable bike storage solution.
- Experts and owners say the rubber coating on the hook is weak and breaks off with minimal use.
- Some reviewers complain that the adhesive tape used to mount the tray doesn’t last, and the tray falls off the wall.
- The rack fits tires up to 2.5”, but inserting and removing mountain bike tires with deep tread can be challenging.
- Mounting the hook requires drilling holes, and additional wall plugs are required for cement walls.
- A stud finder is needed for wood-framed houses and drywall.
- Buyers advise purchasing third-party screws, as the included ones are short, strip easily, and aren’t designed for cement.
Delta Cycle’s Heavy Duty Single Bike Wall Mount–formerly Leonardo da Vinci Wall Mount–is a hook that supports one bike up to 40lb and tires up to 2.5”. Owners praise the easy installation, durability, and stability of mounted bikes. However, the hook’s rubber coating, the tray’s adhesive installation tape, and the included screws are all considered poor quality. Drilling holes is required, and users must mount the rack to a stud when installing on drywall. Owners and experts agree Delta’s Heavy Duty Single Bike Wall Mount is good value, but tire width and weight capacity limits exclude most e-bike owners.BikeRide finds and shows you the best prices of the bikes you want to buy. Prices constantly change and it’s impossible to compare them all yourself.
79/100 based on 2 rated expert reviewsDelta Leonardo Wall Mount Bike Rack Review
Delta Bike Hook – 1 Bike With Wheel Tray
Wall Mount Bike Rack Review – Delta Cycle Leonardo Da Vinci Single Bike Storage Rack Hook Hanger
Best Bike Garage And Storage Racks
Bike Rack Comparison
2 hours ago
16 hours ago
