How to Align a Rear Derailleur Hanger
Derailleur hangers are easily bent and can cause shifting problems.
Today we’ll learn how to straighten integrated derailleur hangers. Shifting problems caused by a bent derailleur hanger are quite common. This can happen if your bike is dropped, crashed or bumped, or if it was poorly aligned at the manufacturer. The result is poor shifting even after all other adjustments have been made.
Tools
For this job you’ll need a repair stand and a hanger alignment gauge like this one called the DAG-2.2 from Park Tool. When compared to bike shop labor charges, it will pay for itself after 3-4 uses. You’ll also need a 5mm hex key for the derailleur mounting bolt, and a string or small strap to hold the derailleur out of the way while you align the hanger.
It is important to make sure your rear wheel is true and properly mounted in the frame dropouts, as the alignment tool compares the derailleur hanger to the rim surface. See the tutorials titled How to Remove and Install Your Wheels and How to True a Wheel.
Tool Installation
The first step is to shift the rear derailleur onto the smallest sprocket and then remove the rear derailleur by turning the mounting bolt all the way counter-clockwise. There is no need to remove the shift cable or chain. Then tie the derailleur up onto the frame to keep it out of the way. If you have a replaceable derailleur hanger, you’ll first want to make sure the bolts holding it in place are properly tightened so they don’t move.
Now thread the tool’s shaft all the way into the hanger threads by turning it carefully clockwise into where the derailleur was mounted. If it doesn’t thread in smoothly, the threads may be damaged and need to be chased with a tap. We’ll cover this in a future tutorial. Do not use the tool’s threads as a thread chaser.
We’ll be checking the alignment at four different places on the rim: the 9 o’clock and 3 o’clock for horizontal alignment, and the 12 o’clock and 6 o’clock for vertical alignment. When aligned correctly, the alignment tool’s indicator will be roughly the same distance from the rim at all four locations.
Horizontal Alignment
For horizontal alignment, move the alignment tool’s arm to the 9 o’clock position and rotate the wheel so the valve is at the same spot. Loosen the knob and slide the indicator so it contacts the outside edge of the rim, and then tighten the knob again to hold the indicator in place. Now rotate the tool arm and valve around to the 3 o’clock position and see where the indicator sits. If the tip of the indicator is within 4mm of the rim on this side then the horizontal alignment is ok. If the difference is more or less than 4mm, carefully pull or push the tool’s arm, using it as a lever to slightly bend the hanger in the right direction, and then re-check the alignment on both sides.
You may need to repeat this process a few times until the alignment is within range. It’s important not to bend the hanger too much with the alignment tool. It’s best to bend it a little bit and then have to bend it some more, rather than bending it too much and having to bend it back again.
Vertical Alignment
For vertical alignment, keep the indicator in the same position and then check the 12 o’clock and 6 o’clock positions the same way we did for the horizontal alignment. Always remember to move the air valve along with the indicator and place the indicator at the outside edge of the rim.
Once the hanger is aligned and within 4mm both horizontally and vertically, unthread the alignment tool. Apply a little waterproof grease to the derailleur’s mounting bolts threads and begin threading it back in clockwise. Make sure the B-screw adjustment is sitting behind the derailleur hanger. Then tighten the derailleur to the specified torque, usually around 8-10 Newton Meters or 70-90 Inch Pounds.
Related Links
Recommended Tools
- Park Tool DAG-2.2 Derailleur Hanger Alignment Gauge
- Park Tool AWS-1 3-Way Hex Wrench
- Park Tool AWS-10 Folding Hex Wrench Set
- Park Tool HXS-1.2 Hex Wrench Set
- Park Tool PCS-9 Repair Stand
- Park Tool PCS-4 Repair Stand
Categories
Latest post 6 days agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 2 weeks agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 1 month agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoCurrently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Latest post 4 months agoMy Trike.jpg (Size: 57.65 KB / Downloads: 50) Wife Trike.jpg (Size: 60.74 KB / Downloads: 50) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Latest post 4 months agoI'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Read moreTrek domane tyre
Latest post 6 months agoRecently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
