important: Nuts and bolts on your bike should always be tightened to the manufacturer's specifications.
How to Tape Drop Handlebars
Learn how to remove and install the handlebar grip tape on road-style drop handlebars.
Video updates
  • 00:18 - Hold the brake hoods back with an elastic band if they won't stay on their own.
  • 00:36 - Loosen your brake cable and compress the brake lever to find the tightening bolt.
  • 01:20 - Wrap in the same direction your hands turn while you're riding.
  • 01:57 - Make sure the tape overlaps the 3" strip as well!
Today we’ll learn how to wrap handlebar tape on road-style drop handlebars. For this job you’ll need a set of handlebar tape, some bar plugs, a sharp knife or razor, and some electrical tape. It’s also a good idea to keep your hands clean throughout the procedure.
Remove Old Tape
The first step is to flip back both brake lever hoods and remove the old tape. Some people like to simply cut it away using a razor blade, but I prefer to unwrap it to avoid scoring the aluminum or damaging the cables. Then remove the plugs from the inside of the bar ends.
Align Brake Levers
Before you begin taping, check the alignment of your brake levers. The bottom of each lever should be in line with the bottom of the handlebar and they should also be inline with the side of your bars. Make sure the cables are securely fastened to front side of the handlebar using electrical tape.
Begin Wrapping
Let’s start with the right side. Your new tape should have come with two extra 3″ strips of tape. Wrap this around the bottom of the brake clamp from the rear end. This hides the gap that is often left behind when you wrap around the lever.
To start wrapping, unpeel a bit of the adhesive backing and start by placing the end of the tape under the end of the bars. You’ll want to leave about half of the tape hanging over the edge on the first wrap, which we’ll tuck into the bar end later. The most common direction to wrap the tape is clockwise on the right side, and counter-clockwise on the left.
While you’re wrapping, make sure each rotation overlaps itself about 1/3. You’ll want to make sure the middle section of adhesive on the backside of the tape is always contacting the bars. Pull on the tape evenly through the process to keep the wrap tight, but be very carful not pull too hard or the fragile tape will snap. Pull off the adhesive backing as you go, as this will keep it from getting dirty until you’re ready to apply it.
Wrap Around the Lever
When you get to the brake lever, try to make sure the top edge of the tape overlaps a little bit of the bottom of the brake lever in order to avoid leaving a gap. Then pull the tape around the back end of the brake clamp and over the top.
Now pull the tape around and continue wrapping the top section of handlebar. Stop wrapping when you get to the handlebar’s clamping ferrule, or about an inch from the stem. If you have handlebar accesories you may want to leave some extra room for them to clamp on. Before you finish, it’s a good idea to go back and check that there are no gaps in your wrap job.
Cut and Tape
Holding the tape in place, cut the remaining angled section of tape away using a sharp blade, so that you are left with a clean cut. Then secure it with a few wraps of electrical tape. Make sure to pull the tape so that it stretches nice and evenly. I like to overlap the end of the handlebar tape and completely seal it with the electrical tape.
Bar End Plugs
Once the wrapping is done, go back to the bar end and tuck the extra tape into the handlebar using the bar plug. This will make it hard to fit the plug in, but if you push it hard enough or use a rubber mallet to tap it in gently it should fit and leave your handlebar ends nice and tidy.
To wrap the left side, repeat the same procedure but remember to start wrapping the tape counter-clockwise instead. The left side should end up being an exact mirror image of the right.
The last step is to flip your brake hoods back to where they were.
Related Links
Recommended Tools
Categories
I live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read more
Rear v-brake repair
Latest post 2 weeks ago
Hi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Read more
Custom Bike part manufacturing
Latest post 1 month ago
Hello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Read more
I have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down.   IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51)   IMG_20250122_105428.jpg (...
Read more
Hi everyone! I hope you're enjoying a great start to 2023. I'm curious to hear your go-to method for getting a chain truly clean. I don't mean, just looks shiny or is good enough for a quick clean after a ride. I want to know what you do when you want to get every last morsel of ground-up, link-destroying, roller-eating, tooth-gnashing crud out of your chain. The Best Chain-Cleaning Recipe Ever?...
Read more
What jockey wheel Red 10 Speed
Latest post 2 months ago
Can anyone advise what type of replacement jockey wheel I need for a 10 speed Red rear mech (it's got 11 teeth)? Bonus points if it's a link to a cheap (ish) one! Thanks...
Read more
Grip Shifters
Latest post 3 months ago
Currently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Read more
9 speed chain on 8 speed bike
All of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read more
Operation of Santa Monica Ebike
Hello - new owner with an How to Operate the bike question. Hopefully, this is easily answered I Bought this bike a few weeks ago - Tested many bikes and finally landed on this particular Santa Monica. However, got busy with Christmas shopping, Life, and not so great weather days distracted me from riding. I also test drove so many that I forgot how to operate it.... I "thought" I remembered, ...
Read more
Gears and derailleur misalignment
Latest post 4 months ago
  My Trike.jpg (Size: 57.65 KB / Downloads: 50)   Wife Trike.jpg (Size: 60.74 KB / Downloads: 50) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Read more
I'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Read more
Shifting is almost impossible
My wife's road bike has Shimano Sora shifters with a triple front derailleur (stock). The thumb switch on the front shifter is VERY hard to use and she can't do it when she's riding. I did a full adjustment of the front derailleur but it didn't change anything. One thing that I noticed is that the shifter works smoothly when the shifter cable is unattached from the derailleur, suggesting that the ...
Read more
7-speed bicycle with bent rim
Latest post 5 months ago
I recently bought a 7-speed bicycle practically brand new it still has a little rubber nipples on the tires apparently it got backed into in the garage and it bent the rear rim sideways my question is can I go out and buy another just like single speed 20 inch bicycle and put the 7-speed cassette onto that rim?...
Read more
Trek domane tyre
Hi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read more
Schwinn meridian rear drive axle
Latest post 6 months ago
Recently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
