We have read all expert and user reviews on the EUNORAU META Foldable. In summary, this is what cyclists think.
- This bike comes with a 15Ah battery, but buyers can purchase a second 15Ah or 17Ah unit that mounts to the down tube.
- An expert praises the responsive pedal assist and quick throttle acceleration.
- A 180lb reviewer of the 15Ah META Foldable gets 31 miles of range on a flat paved route using mostly the throttle.
- This bike has fenders, a 55lb-capacity rear rack, a headlight, and a taillight with brake activation.
- Testers commend the hydraulic disc brakes for their reliable stopping power.
- The META Foldable has a height-adjustable stem and quick-release handlebar for easy modifications to fit.
- The low 15” standover height and wide step-through make the bike easy to mount and dismount, even with the second battery installed.
- The display has a USB-A port to charge devices on the go.
- The META Foldable is available in five colorways.
9 reasons not to buy
- Testers reach 30mph with the throttle unlocked. This exceeds e-bike speed limits.
- A reviewer experiences ghost pedaling past 16mph.
- When folded, the META Foldable measures 41.3” x 30.7” x 22”, larger than most competing models with 20" wheels.
- At 63.4 or 71.9lb with the second 17Ah battery, the META Foldable is heavy for a folding e-bike.
- A tester finds the 610mm handlebars too narrow.
- The 2A charger returns slow charging times.
- An expert describes the thumb throttle as cheap and flimsy.
- Though removable, the battery is tricky to take out, with the fork and fenders getting in the way.
- The taillight's wiring under the rear fender is prone to coming loose, according to a tester.
EUNORAU's META Foldable is a folding e-bike with a 500W motor and 720Wh battery. This bike supports a second 720Wh or 816Wh battery (purchased separately). Testers praise the responsive motor, climbing ability, solid range, and strong brakes. The wide step-through frame and adjustable stem and handlebars add to user-friendliness. However, the high weight, large folding dimensions, and tricky battery removal reduce the bike's practicality as a folder. The limited gearing range also results in ghost pedaling after just 16mph. While the two testers consider the META Foldable a good option in this segment, it faces strong competition.Expert Reviews
87/100 based on 2 rated expert reviewsThis Bike Goooooes! | EUNORAU META
EUNORAU META: 20 Inch Foldable E-Bike With Great Power!
5 hours ago
18 hours ago
