How to Securely Fasten Zip Ties
Learn how to use a 4th hand cable puller tool to securely fasten a zip tie.
Video updates
- 00:42 - A set of 'flush cutters' will get the cut nice and clean.
Today we’ll learn how to tighten zip-ties using a 4th hand cable puller tool. The 4th hand was designed to pull the cable tight when you adjust the cable tension on your brakes and derailleurs. It functions by gripping the cable, and then pulling it. While it works great for that job, did you know that you can also use it to securely fasten zip-ties?
I’ll demonstrate here by attaching a piece of cable housing to the frame. Wrap the zip-tie around the frame and cable and snug it up like you normally would. Then use the 4th hand tool to cinch it up a few more clicks. Be careful not to pull it too tight or the zip-tie will snap.
This gets it nice and tight and it looks a lot cleaner than other methods like electrical tape. Once you’re happy with it, snip the remaining section off.
You can get zip-ties in a variety of colors if you want to match your bike or get creative, and you can use different sizes for other jobs like attaching cycle computers, fender stays and so many other do-it-yourself projects! The 4th hand is hands-down one of my favorite tools. I highly recommend getting one for your own home repair kit!
Related Links
Recommended Tools
- Hozan 4th Hand Cable Puller
- Park Tool WTK-2 Essential Tool Kit
- Park Tool PCS-9 Repair Stand
- Park Tool PCS-4 Repair Stand
Categories
Latest post 35 mins agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 4 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 4 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Read moreTrek domane tyre
Read more
