Freesky Boulevard F-2880
76/100
7 Hours
80 Miles
29 mph
100 Nm
48V 20Ah
82 lb
We have read all expert and user reviews on the Freesky Boulevard F-2880. In summary, this is what cyclists think.
  • Testers say the four-piston hydraulic disc brakes provide strong stopping power.
  • An expert appreciates the responsive pedal assist.
  • One tester praises the motor's quick acceleration and power, easily tackling inclines.
  • Reviewers enjoy how the full suspension helps smooth out bumpy roads.
  • The Boulevard F-2880 comes with a headlight, taillight with brake activation, an integrated 55lb-capacity rear rack, fenders, tools, and a chain lock.
  • A reviewer reports stable handling while riding at high speeds.
  • In a range test, the 225lb reviewer gets 31.2 miles of city riding.
  • The low step-through frame is easy to get on and off.
13 reasons not to buy
  • The Boulevard F-2880's large folded size (36” x 31.5” x 17.7”) and high weight of 82lb mean carrying and transportation are impractical.
  • An expert finds throttle power delivery too aggressive.
  • A reviewer notes the handlebar is too high in relation to the seat when both are set at their minimum height.
  • The 20.1" reach is too long for riders at the low end of the stated height range of 5’1” to 5’11”.
  • Testers report ghost pedaling from speeds over 14mph.
  • This bike reaches roughly 30mph using pedal assist, exceeding e-bike regulations.
  • Reviewers complain that the speedometer and odometer are inaccurate.
  • Experts and owners agree the uncomfortable saddle should be replaced immediately.
  • Testers' bikes have stickers covering unused mounts in the frame above and below the integrated battery.
  • An expert says the manual inaccurately states the front wheel axle spacing.
  • With the seat lowered, some of the rear rack is unusable as the rider sits over it.
  • One reviewer feels vibrations from the motor coming through the seat.
  • The manual and website have contradictory specs for weight, range, and water resistance.
The Freesky Boulevard F-2880 is a folding fat-tire e-bike with a 750W motor and 960Wh battery. Review content is sparse. The two expert reviews report excellent stopping power and a smooth ride on pavement. One reviewer finds the bike powerful, accelerating quickly and climbing well. The other feels it’s underpowered. Notable issues include ghost pedaling above 14mph, imprecise display metrics, high weight, and an impractically large folded size. Overall, the Freesky Boulevard F-2880 fails to stand out in a flooded segment of fat-tire folders.
78/100 based on 2 rated expert reviews
Scott Hardesty
Airshow Causes Chaos During the Freesky Boulevard Review
If you are looking for a foldable e-bike that has a lot of power, the Freesky Boulevard could be the bike for you.
Maximum Charge
Dual Suspension Foldable! Freesky Boulevard Review
… shorter rider, this bike is great. You will fit easily on this bike, although just remember your hands will be a little bit higher up than you’re probably used to. If you need something foldable, this is a great option.
80/100 based on 4 ratings
    75%
    25%
#399 Best Electric
Bottom 20%
#75 Best Folding
Bottom 20%
#5 Best Freesky Bike
Bottom 20%
#732 Best of All Bikes
Bottom 20%
Freesky Boulevard F-2880 in comparison to averages
76
