Freesky Warrior Pro M-530
88/100
10 Hours
95 Miles
36 mph
2000 W
200 Nm
48V 30Ah
97 lb
We have read all expert and user reviews on the Freesky Warrior Pro M-530. In summary, this is what cyclists think.
6 reasons to buy
  • Testers of the dual-motor Warrior Pro M-530 easily maintain speeds of 35mph over flat ground.
  • Reviewers relish the bike's ability to climb hills in dual-motor mode.
  • The immediate delivery of pedal assist power delights testers.
  • Experts say the suspension handles small bumps well, on and off-road.
  • Experts and owners find the Warrior Pro M-530 comfortable to ride.
  • Owners praise Freesky’s responsive and helpful customer support.
14 reasons not to buy
  • Reviewers and owners caution over the aggressive initial power delivery in dual-motor mode.
  • Testers report the front wheel spinning out in front-wheel drive.
  • Experts warn the aggressiveness of dual-motor mode and the loss of traction in front motor mode make them ill-suited to off-road riding.
  • The front motor activates after a delay of a few seconds, surprising testers with a burst of power.
  • Reviewers fail to reach Freesky’s claimed top speed using PAS due to the limited gearing range.
  • At 97lb, the Warrior Pro M-530 is heavy, difficult to maneuver, and only suitable for light off-roading.
  • Two reviewers complain that the low-end 4” Chaoyang tires provide poor grip.
  • Experts find the non-adjustable rear shock too stiff.
  • Two testers feel the 180mm brake rotors are too small for a bike this heavy and fast.
  • Experts say the Bluetooth companion app is unhelpful.
  • The Warrior Pro M-530 doesn't come with a taillight.
  • Testers over 6’ tall recommend replacing the short seatpost while being mindful of the limited space above the rear shock.
  • One reviewer’s front light rattles loose after a bumpy commute.
  • The password to power the Warrior Pro M-530 on without the need for the NFC key must be obtained by contacting customer support.
The Freesky Warrior Pro M-530 is a fat tire e-bike with two 1000W motors and a 1440Wh battery. Testers praise the bike's ability to climb any hill and maintain high cruising speeds. The ride comfort impresses, though some testers find the rear shock too stiff. The 180mm brake rotors are undersized for a bike this heavy. Freesky's responsive customer support wins points with owners. The main complaints are over the front motor's delayed activation, overly aggressive acceleration in dual-motor mode, limited gearing, and cheap tires. Overall, reviewers and owners consider the Warrior Pro M-530 good value despite its faults.
76/100 based on 3 rated expert reviews
71
Ebike Commuter
Freesky Warrior Review
Sure, you could get a faster bike or a more comfortable bike, but you’d be hard-pressed to find a bike that is this fast, this competent, and this comfortable at this price.
The Bike Cave
The Cheapest Dual Motor 35MPH E-Bike – Freesky Warrior Pro Review
The first type of person that comes to mind… that would fit this bike very well is going to be someone that wants a lot of acceleration, [and] maybe someone that’s on the heavier side.
CitizenCycle
Freesky Warrior Pro: Dual 1000W Motors for [Price]
I found myself riding in single-motor mode most of the time, just rear-wheel drive… It was still very strong, had lots of power, and it was a smoother power delivery. I didn’t have the front motor kicking in and out.
Wild 2WD Electric Fat Bike! Freesky Warrior Test Ride
The seatpost was not long enough for me at 6’ tall… On the plus side, two-wheel drive is… a lot of fun to experience. The bike is also fast…
This Dual Motor E-Bike Is Actually Really Fun – Freesky Warrior Pro M-530 Review
This thing pulls pretty hard. I’m not a huge fan of the delay on the front motor before it kicks in… [The] thumb throttle is not my favorite, but for the price, what you get for the money is not bad…
97/100 based on 41 ratings
    90%
    7%
    2%
#119 Best Electric
Top 30%
#43 Best Fat Tire
Top 20%
#1 Best Freesky Bike
Top 20%
#235 Best of All Bikes
Top 30%
Freesky Warrior Pro M-530 in comparison to averages
