How to Shift Your Gears
Learn how to use your full range of gears: applies to 21, 24, and 27 speed shift systems.
Video updates
- 02:14 - Never use either the large/large or small/small gear combination!
Most bikes these days come with ’21 speeds’. However, this doesn’t mean you have 21 useable gears. Actually, on a 21 speed system it’s closer to 13. A lot of people get confused by all of the gear combinations available. I myself didn’t understand it when I first started using a multi-speed bike, so today we’ll learn how to use your gears most effectively.
It’s very important not to shift under pressure, as this will cause shift problems and damage your drivetrain. If you’re going uphill and you need a lower gear, keep pedaling, but ease off and pedal lightly while you shift.
Most systems have three gears on the front, which are controlled by your left shifter. The rear gear cluster usually has 7 gears, with some systems having 8 or 9. Not to worry, the concepts here are the same.
For most everday riding, you’ll want to keep your chain on the middle ring on the front, or number 2 on your left shifter. This allows you to use the full range of rear gears. Number 1 on your right shifter is the easiest gear for climbing hills, as it puts your chain on the largest rear sprocket. Number 7 on your right shifter is the hardest gear for going really fast, and it puts your chain on the smallest rear sprocket.
I find it helps to think of numbers 1 and 3 on your left shifter as options for extreme circumstances.
If you’re climbing a really tough hill and your left 2 and right 1 combination aren’t easy enough, you can shift your front derailleur to number 1 which drops the chain down to the smallest front chainring. While you’re in the smallest front gear you can shift the rear gears between 1 and 3 for a finer range adjustment, but you should always shift the front back to 2, or the middle chainring before using gears 4-7 on the rear.
If you’re going really fast and need a harder gear, and your left 2 and right 7 combination isn’t fast enough, you can shift your front derailleur to number 3 which pulls the chain up to the largest front chainring. While you’re in the largest front chainring you can shift the rear gears between 5 and 7 for a finer range adjustment, but always shift the front back to 2, or the middle chainring before using gears 1-4 on the rear.
Never use the full range of rear gears when you’re in either the small or large front sprockets (number 1 or 3 on the front shifter). This causes too great an angle in your chain line, which can cause noise and shifting problems.
Related Links
- Jim Langley: How to Shift A Bicycle
- Sheldon Brown: Shift Your Bicycle's Gears
Recommended Tools
- Park Tool CG-2 Chain Gang Chain Cleaning System
- Park Tool GearClean Brush GSC-1C 11
- Finish Line Wet Chain Lube (Cross Country)
- Phil Wood Tenacious Oil
Categories
Rear v-brake repair
Latest post 1 day agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 3 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 49) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoMy Trike.jpg (Size: 57.65 KB / Downloads: 49) Wife Trike.jpg (Size: 60.74 KB / Downloads: 49) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Read moreTrek domane tyre
Read moreBianchi Oltre Pro Garmin Mount
Latest post 6 months agoI am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
