How to Replace a GripShift Cable
Learn how to disassemble and reassemble a twist shifter to replace the inner shift cable.
Today we’ll learn how to replace a Sram GripShift(R) style shifter cable. For this job, you’ll need a replacement shift cable and end cap, a 2.5mm allen key to open the grip shifter, a 5mm allen key or 9mm open end wrench to loosen the derailleur pinch bolt and brake levers, a cable cutter to trim the cable and pinch the cap, some light oil to lube the cable housings and a tiny bit of waterproof grease for inside the shifter.
Remove Old Cable
The first step is to remove the old cable. Shift either your front or rear derailleur to the smallest sprocket and cut the old cable cap off. Then loosen the pinch bolt and slide the inner cable out of the derailleur and cable housings.
Disassemble Shifter
Now loosen your brake lever and slide it along the handlebar so we have room to open the grip shifter unit. Turn the shifter to the highest gear if you’re replacing the rear cable, or the lowest gear if you’re replacing the front. You’ll notice a small allen bolt on the outside of the shifter body. Loosen this off but don’t un-thread it completely as they are really easy to lose.
Once the shifter turns freely on the handlebar, jiggle and pull the grip apart until it separates into two parts. Sometimes it helps to very gently pry it open with a flat screwdriver.
Now you’ll have to be extra careful. The first thing watch for is a tiny piece of oddly-shaped metal sitting on the inside of the shifter. It’s really important to keep that spring exactly where it is as the shifter won’t function without it. Slide the old cable out of the shifter and pay careful attention to how it was wrapped around inside the shifter. The cable usually wraps around once and sits in a little groove.
Reassemble Shifter
Apply a tiny dab of grease to the grooves where the cable sits inside the shifter. Slide the new cable back into the shifter, loosely wrap it around once, and then slide it through the shifter body. Now pull the cable tight and set it down into the shifter grooves the same way it came out. If it looks right, push the two parts of the shifter back together and try turning the shifter. If the cable is installed correctly it should click and turn normally. Slide your brake lever back into position and tighten it. Now turn the shifter so the cable is tucked up under the brake lever and tighten it as well.
Install New Cable
Drop a little bit of light oil into the cable housings before installing the new cable. Thread the inner cable back through the housings and the derailleur pinch bolt. Make sure your shifter is in the smallest sprocket and then pull the cable tight and tighten the bolt. Now run through the gears and adjust your front or rear derailleur as needed.
The last step is to cut the excess cable off about two inches past the pinch bolt. Then slide on the aluminum cap and just partially squish it 2 or 3 times with your cable cutter so that it stays on. This will keep the cable from fraying.
Related Links
Recommended Tools
- Park Tool HXS-1.2 Hex Wrench Set
- Park Tool SD-Set Shop Screwdrivers
- Tri-Flow Superior Lube
- Park Tool WTK-2 Essential Tool Kit
Categories
Rear v-brake repair
Latest post 3 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 4 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Read moreTrek domane tyre
Read moreBianchi Oltre Pro Garmin Mount
Latest post 6 months agoI am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
