We have read all expert and user reviews on the Ibis Ripley. In summary, this is what cyclists think.
19 reasons to buy
- The Ripley is one of the lightest trail bikes available to consumers.
- The bike's carbon frame has a 7-year warranty.
- The DW-Link suspension provides an efficient pedaling platform, excellent mid-stroke support and big-hit compliance for riders on the Ibis Ripley.
- The Ibis Ripley is lightweight and has a steep seat tube angle positioning the rider efficiently for climbing.
- Experts found the bike was agile and very responsive to rider input, with the steep seat tube angle, slack head tube angle, long wheelbase, 44mm reduced offset and short chainstay.
- The Ibis Ripley climbs well, even when the shock is in the open position. Experts found that energy was not wasted through suspension bob.
- The 44mm reduced offset fork keeps the bike from feeling unruly through tight uphill switchbacks or slow technical sections.
- The geometry of the bike is not too slack or steep. Experts note the bike is well-balanced and allows riders to ride over a great variety of terrain.
- Experts agree the bike accelerates quickly on flats and moderate climbs.
- The bike has clearance for tires up to 2.6” wide.
- The 2.6” Schwalbe Hans Damf and Nobby Nics on 29” wheels create excellent traction and rollover for riders. The stock tire and wheel combination allows riders to corner predictably and maneuver over roots and rocks with ease.
- Riders can run a longer dropper post on the Ripley as the suspension setup allows for an uninterrupted seat tube.
- The suspension utilizes IGUS bushings, which help reduce the weight of the bike. They also require less maintenance.
- The bike has a polycarbonate downtube protector and molded swingarm protectors to protect the frame from debris and obstacles on the trail.
- The Ibis Ripley has molded tubing for internally routing cables. This gives the bike a neat appearance.
- The threaded bottom bracket is quiet and easy to maintain on the Ripley.
- There is room for a water bottle in the lower triangle of the bike.
- Custom bags can easily be used in the bike’s frame to transform the bike into a capable bikepacking mountain bike.
- The Bike Yoke dropper post on the Ibis Ripley is self-bleeding. This makes it easy for riders to reset the dropper post on trail, if necessary.
2 reasons not to buy
- Experts noted that they could easily be bucked around on rocky descents, riding the Ripley.
- The sizing of the bike runs small, according to numerous experts.
The Ibis Ripley is a short travel trail bike. It utilizes 29” wheels and DW-Link suspension to provide riders with a comfortable ride over almost any trail. The bike excels on climbs and is stable on most descents. Experts noted they could be tossed around at times on the downhill. The bike has room for a water bottle or two bags in the frame, allowing the Ripley to take on longer day rides or bikepacking adventures. The bike is available in sizes small to XL, but experts agreed the sizes run small.Expert Reviews
83/100 based on 2 rated expert reviewsBike Build + Review: Ibis Ripley Mark 4
Ibis Ripley GX Eagle 2019 Review
Ibis Ripley XRT
Ibis Ripley V4 Mountain Bike Review
2020 Ibis Ripley Long Term Review
Ibis Ripley Gen 4 2020: Best Trail Bike Ever
2020 Ibis Ripley Review
2020 Ibis Ripley Test Ride and Review: The King of Short Travel 29ers!
The Ibis Ripley V4 Review
Should You Buy the New Ibis Ripley? (Ripmo Replacement?)
Ibis Ripely V4 – Best in Class 2020
Review: Ibis Ripley
Ibis Ripley Review, V4
2020 Ibis Ripley – Long Term Review
Review: XTR Equipped Ibis Ripley V4 May Be the Perfect Mix of Short Travel & Fun
The New Ibis Ripley is a Lively Shred Sled
MBA Bike Test: Ibis Ripley V4
Review: The Updated and Refined Ibis Ripley 29er Trail Bike is Lighter, Even More Capable
Review: The Ibis Ripley
Best Mountain Bikes
2 hours ago
16 hours ago
