iGO Outland Sawback RS
82/100
7.5 Hours
45 Miles
130 Nm
48V 15Ah
68.1 lb
We have read all expert and user reviews on the iGO Outland Sawback RS. In summary, this is what cyclists think.
7 reasons to buy
  • A reviewer praises the immediate pedal assist engagement and disengagement.
  • Experts relish the throttle's responsiveness and fast acceleration.
  • A reviewer covers 40 miles using max pedal assist in a flat, paved range test.
  • The Sawback RS performs very well in hill tests using the throttle.
  • The 2.4" Maxxis Ardent EXO tires offer a good mix of grip and efficiency on one reviewer's dry, rocky test trails.
  • The Outland Sawback RS has a throttle, unlike most mid-drive e-bikes.
  • One expert appreciates the inclusion of a dropper seatpost for off-road descending.
11 reasons not to buy
  • The Outland Sawback RS isn't UL-certified.
  • The steep head angle, slack seat tube angle, and long wheelbase and chainstays are ill-suited to mountain biking.
  • The Sawback RS is very heavy (68lb) for a model marketed as an e-MTB.
  • The entry-level Tektro HD-E350 brakes demonstrate poor stopping power in testing.
  • The Shimano Alivio 9-speed drivetrain is cheap and lacks the gearing range for pedaling on steep inclines.
  • The Sawback RS comes in only one size.
  • The stated 5'3" to 6'2" height range is exaggerated. Riders at the low end will struggle with the 30.3" standover height.
  • A tester complains that the drivetrain rattles a lot over bumpy terrain.
  • The Suntour XCM 34 performs poorly on rocky MTB trails in testing.
  • An expert removes the throttle for off-road riding, as its position interferes with the dropper lever. Using a throttle is also illegal on most off-road trails.
  • iGO doesn't provide lights with this Sawback RS.
The iGO Outland Sawback RS is a mid-drive e-bike marketed as an e-MTB. Unfortunately, the sole expert review finds it falls short as an e-MTB. A cheap and limited drivetrain, urban-style geometry, entry-level coil fork, weak brakes, and very high weight make this bike a poor choice for actual mountain biking. That said, the responsive pedal assist, powerful throttle, solid Maxxis Ardent cross-country tires, and decent range make the Outland Sawback RS a reasonable—albeit overpriced—option for those looking to tackle smooth dirt and gravel trails with some steep climbs.
86/100 based on 1 rated expert review
iGO Outland Sawback RS Review, 2024
It’s a pleasantly powerful and fun e-MTB that can make short work of dirt paths, and with Class 3 capabilities, it can also keep up with traffic for a safer ride on the morning commute.
#279 Best Electric
Bottom 40%
#57 Best Hybrid
Bottom 40%
#1 Best iGO Bike
Top 20%
#508 Best of All Bikes
Bottom 50%
iGO Outland Sawback RS in comparison to averages
