How to Install a Front Derailleur
Removal and installation of a standard clamp-on front derailleur.
- How to Adjust Your Front Derailleur
- How to Replace an Inner Shift Cable
- How to Lubricate Brake and Shift Cables
- How To Install a Rear Derailleur
Today we’ll learn how to replace a standard band-type clamp-on front derailleur. We’ll cover the E-Type bottom bracket mounted derailleurs in a future tutorial.
Tools
For this job you’ll need a 5mm hex key for the derailleur’s mounting bolt, and a phillips(+) screwdriver to adjust the derailleur’s limit screws and remove the derailleur cage bolt. If you are removing the chain you may need a chain tool depending on your type of chain. You’ll also need wire cutters and either a 9 or 10mm metric open end wrench or a 5 or 6mm hex key to remove and install the front shift cable.
Front Derailleur Removal
The first step is to shift your chain onto the smallest front chainring. Then pull off the shift cable’s end cap and loosen the cable pinch bolt. Remove the cable from the derailleur.
Now you’ll need to remove the chain from the derailleur. Some chains have a special connector pin that need replacing if removed, so if you don’t need to remove the chain for cleaning or replacement you can simply undo the derailleur cage’s tail screw and flex the cage open to release the chain. Rest the chain on the bottom bracket shell to keep it out of the way.
If you are removing the chain, disconnect a link and pull the chain through the derailleur cage. Now you can undo the derailleur’s mounting bolt all the way counter clockwise to remove the derailleur from the frame.
Front Derailleur Installation
Before installing the new front derailleur, apply some waterproof grease to the mounting bolt. Then place the clamp around the frame and tighten the mounting bolt just enough to keep it in place. At this point you still need to be able to move it by hand.
Now adjust the derailleur’s height and angle. For height adjustment, the bottom edge of the outside derailleur cage should sit approximately 2mm above the top of the teeth on the largest chainring. For the angle adjustment, rotate the derailleur until the cage is parallel with your chainrings. Then fully tighten the clamp’s mounting bolt.
If your chain is still on the bike, undo the tail screw on the derailleur cage and flex the cage to pull the chain through. Then re-install and tighten the tail screw again. If you have removed the chain, re-route the chain through the derailleur cage and reconnect it. Search the site for tutorials on how to use a chain tool or a quick release chain link.
Front Derailleur Set-up
Now preset the low-limit (L) screw so the small chainring appears halfway between the derailleur cage when viewed from above.
Thread the shift cable back into the derailleur, pull it tight and tighten the anchor bolt so the cable flattens. Then find a bare stretch of cable and give it a good pull to make sure the cable is seated and has no slack. Then loosen the cable, pull it tight again and re-tighten it.
Now you’re ready to adjust the front derailleur as shown in previous tutorials. If necessary, trim the cable so there is about 2 inches remaining. Then slide on a cable end cap and crimp it in place.
Related Links
Recommended Tools
- Park Tool HXS-1.2 Hex Wrench Set
- Park Tool Wrench Combo Set
- Park Tool SD-Set Shop Screwdrivers
- Shimano TL-CT10 Cable Cutter
Categories
Latest post 7 days agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 2 weeks agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 1 month agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 51) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoCurrently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Latest post 3 months agoAll of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Latest post 4 months agoMy Trike.jpg (Size: 57.65 KB / Downloads: 50) Wife Trike.jpg (Size: 60.74 KB / Downloads: 50) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Latest post 4 months agoI'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Read moreTrek domane tyre
Latest post 6 months agoRecently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
