important: Nuts and bolts on your bike should always be tightened to the manufacturer's specifications.
How to Install a Rear Derailleur
Removal and installation of a standard bolt-on rear derailleur.
In this tutorial we’ll learn how to replace a standard bolt-on rear derailleur.
Tools
For this job you’ll need a 5mm hex key for the derailleur’s mounting bolt, and a 2.5mm or 3mm hex key for the jockey wheels if you will not be removing the chain to clean or replace it. If you are removing the chain you may need a chain tool depending on your type of chain. You’ll also need wire cutters and a 9 or 10mm metric open end wrench, or a 5 or 6mm hex key to remove and install the rear shift cable. The last thing you’ll need is a phillips (+) screwdriver for adjusting the derailleur’s limit screws.
Rear Derailleur Removal
The first step is to shift your chain onto the smallest rear sprocket. Then pull off the shift cable’s end cap and loosen the cable pinch bolt. Remove the cable from the derailleur.
Now you’ll need to remove the chain from the derailleur. Some chains have a special connector pin that need replacing if removed, so if you don’t need to remove the chain for cleaning or replacement you can simply remove the lower jockey wheel and rotate the cage plate to release the chain. If you are removing the chain, disconnect a link and pull the chain through the jockey wheels.
Now you can unthread the derailleur’s mounting bolt all the way counter clockwise to remove the derailleur.
Rear Derailleur Installation
Before installing the new rear derailleur, apply some waterproof grease to the mounting bolt. Then thread it part way into the derailleur hanger, and rotate it clockwise to make sure the b-screw or tab is sitting behind the flat on the back of the hanger. Then fully tighten the mounting bolt.
If your chain is still on the bike, undo the bottom jockey wheel and thread the chain over the top pulley. Then re-install the lower jockey wheel. If you have removed the chain, re-route the chain through the jockey wheels and reconnect it. Search the site for tutorials on how to use a chain tool or a quick release chain link.
Rear Derailleur Set-up
Now preset the high-limit (H) screw so the upper jockey wheel is roughly in line with the smallest sprocket when viewed from behind.
Thread the shift cable back into the derailleur, pull it tight and tighten the anchor bolt so the cable flattens. Then find a bare stretch of cable and give it a good pull to make sure the cable is seated and has no slack. Then loosen the cable, pull it tight again and re-tighten it.
Now you’ll need to adjust the rear derailleur as shown in previous tutorials. If necessary, trim the cable so there is about 2 inches remaining. Then slide on a cable end cap and crimp it in place.
Related Links
Recommended Tools
Categories
Rear v-brake repair
Latest post 2 days ago
Hi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Read more
Custom Bike part manufacturing
Latest post 4 weeks ago
Hello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Read more
I have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down.   IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50)   IMG_20250122_105428.jpg (...
Read more
Hi everyone! I hope you're enjoying a great start to 2023. I'm curious to hear your go-to method for getting a chain truly clean. I don't mean, just looks shiny or is good enough for a quick clean after a ride. I want to know what you do when you want to get every last morsel of ground-up, link-destroying, roller-eating, tooth-gnashing crud out of your chain. The Best Chain-Cleaning Recipe Ever?...
Read more
What jockey wheel Red 10 Speed
Latest post 2 months ago
Can anyone advise what type of replacement jockey wheel I need for a 10 speed Red rear mech (it's got 11 teeth)? Bonus points if it's a link to a cheap (ish) one! Thanks...
Read more
Grip Shifters
Currently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Read more
9 speed chain on 8 speed bike
All of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read more
Operation of Santa Monica Ebike
Latest post 3 months ago
Hello - new owner with an How to Operate the bike question. Hopefully, this is easily answered I Bought this bike a few weeks ago - Tested many bikes and finally landed on this particular Santa Monica. However, got busy with Christmas shopping, Life, and not so great weather days distracted me from riding. I also test drove so many that I forgot how to operate it.... I "thought" I remembered, ...
Read more
Gears and derailleur misalignment
  My Trike.jpg (Size: 57.65 KB / Downloads: 49)   Wife Trike.jpg (Size: 60.74 KB / Downloads: 49) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Read more
I'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Read more
Shifting is almost impossible
Latest post 4 months ago
My wife's road bike has Shimano Sora shifters with a triple front derailleur (stock). The thumb switch on the front shifter is VERY hard to use and she can't do it when she's riding. I did a full adjustment of the front derailleur but it didn't change anything. One thing that I noticed is that the shifter works smoothly when the shifter cable is unattached from the derailleur, suggesting that the ...
Read more
7-speed bicycle with bent rim
Latest post 5 months ago
I recently bought a 7-speed bicycle practically brand new it still has a little rubber nipples on the tires apparently it got backed into in the garage and it bent the rear rim sideways my question is can I go out and buy another just like single speed 20 inch bicycle and put the 7-speed cassette onto that rim?...
Read more
Trek domane tyre
Hi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read more
Schwinn meridian rear drive axle
Recently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
Bianchi Oltre Pro Garmin Mount
Latest post 6 months ago
I am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
