How to Install Tektro Auriga Comp Disc Brakes
Learn how to install Tektro Auriga Comp hydraulic disc brake rotor, levers and calipers.
In this tutorial we’ll learn how to install Tektro Auriga Comp Disc Brakes. We’ll be covering other brands in future tutorials.
What You’ll Need
For this job you will need 2, 4 and 5mm allen wrenches and a T25 torx wrench. Your bike will also need to have compatible disc brake mounts on both the hubs and frame and fork.
Rotor Installation
First you’ll have to remove the wheel from the bike. Attach the rotor to the hub using the supplied bolts, making sure the rotation direction of the disc is installed in the same direction of the forward wheel movement. Tighten all 6 bolts with your T25 torx wrench until they are snug but not fully tightened. Then fully tighten the bolts in the following pattern until all are equally tightened to 4-6Nm.
Lever Installation
Place the brake lever with the half clamp on the handlebars, with the hose facing toward the center of the handlebars. Tighten the brake lever clamp in the desired position with a 4mm allen bolt. Tighten these bolts to 5-7Nm. If needed, adjust the brake lever reach closer to the handle bars with a 2mm allen wrench.
Caliper Installation
Before installing the disc caliper adapters, make sure your wheel axle is fully seated in the dropouts with the brake rotor on the caliper mounting side. Mount the adapter with the engraved F or R facing towards the axle as shown. Tighten the adapter bolts to 6-8Nm of torque.
Make sure the pads are correctly positioned in the caliper, then place the caliper over the rotor with the bleed screw facing away from the wheel. Attach the caliper to the adapter using the supplied allen bolts. Loosely tighten the bolts so you can still move the caliper.
Pad Adjustment
With the caliper mounting bolts loose, fully depress the brake lever and keep the lever depressed so the caliper correctly centers itself on the rotor. With the brake lever depressed, tighten the caliper mounting bolts to 6-8Nm. Use a zip tie to fasten the brake hose to ensure it is out of the way.
In our next tutorial we will cover how to bleed the brake lines on this model.
Related Links
Recommended Tools
- Park Tool TWS-2 Fold-Up Torx Compatible Wrench Set
- Park Tool AWS-10 Folding Hex Wrench Set
- Park Tool HXS-1.2 Hex Wrench Set
- Park Tool Wrench Combo Set
- Tektro Auriga Comp Hydraulic Disc Brake (Front)
- Tektro Auriga Comp Hydraulic Disc Brake (Rear)
Categories
Latest post 2 hours agoI live 5 km from the ocean (not sure if that's relevant), and I pretty much only mountain bike. After every ride, I hose down and clean my bike. I wipe them down with a cloth. After a few days, the ones not ridden have what looks like surface rust appear on the chain. Do you have any cost-effective remedies to solve this issue?...
Read moreRear v-brake repair
Latest post 5 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 4 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Read moreTrek domane tyre
Read more
