We earn affiliate commission.
Learn more
4 Hours
42 Miles
15.53 mph
70 Nm
36V 14Ah
47.40 lb
We have read all expert and user reviews on the Intense Tazer. In summary, this is what cyclists think.
17 reasons to buy
- Progressive geometry suited fast, winding trails while maintaining a stable ride.
- In ‘boost’ mode, riders said it climbed rugged hills with the vigor of a frightened cat.
- Fox’s e-bike 36 GRIP2 suspension fork was described as “sublime” by one expert.
- A steep seat angle kept riders’ weight forward on climbs.
- The Tazer’s rear linkage and DPX2 suspension setup was progressive and deep.
- Shimano’s STEPS E8000 system kicked in assist with absolute minimal lag.
- A long reach kept the Tazer stable at speed and comfortable on long-distance rides.
- The wide 2.8” rear tire on a 27.5” wheel, dug in with ample traction on climbs.
- Riders can select their level of input with three levels of assist; Eco, Trail and Boost.
- In tests, Maxxis Minion tires were grippy and tough.
- A 504Wh battery allowed for ample ride distance without concern over running flat.
- Under assist, the 11-speed Shimano SLX drivetrain provided generous range.
- Shimano’s full-color control unit was compact, direct and straightforward.
- The Shimano STEPS 504 Wh battery is designed to be easy to swap out at the trail.
- The width and shape of the Intense Recon Alloy handlebar satisfied experts.
- There is room to attach a water bottle cage in the main triangle of the Tazer.
- Powerful braking is supplied by Shimano 4-piston hydraulic brakesets with 200mm disc rotors.
- An expert felt that reach on the Tazer was too long.
- A test rider wasn’t too impressed by battery life on the STEPS E8000 system.
- Battery rattle was consistent on one reviewer’s test-bike.
- A long-term reviewer said the battery compartment let in a little water.
- The Fox Transfer dropper seatpost sometimes failed to fully extend.
- One reviewer felt that rear wheel clearance was limited, moreso with a fender attached.
The Tazer is a premium e-bike from a company with extensive mountain bike credentials. Components were uniformly lauded for quality and performance, although some reviewers expected more of a drivetrain than Shimano SLX (for the Tazer’s not-insignificant price). This was a bike for those who liked to ride hard and ride long – and that’s how experts found it liked to be ridden. For this reason, Intense designed the Tazer with the expectation that riders would want to swap out their depleted battery for a backup unit on epic travails. Stability was awesome, due to a low center-of-gravity and looong reach. For some, this reach was a little too long, leading experienced e-mountainbikers to choose a size smaller than their usual.Expert Reviews
80/100 based on 1 rated expert reviewIntense Tazer eMTB Review
Reviewed: Intense Tazer
Intense Tazer Long Term Review
Intense Tazer
The Intense TAZER and My 2 Favorite eBike Uses!
Intense Tazer eMTB – First Impressions
Intense Tazer E Bike Honest Review. Are Mixers Rad or a Fad?
Intense Tazer Review
Intense Tazer e-MTB First Ride Review
Intense Tazer Pro Electric Mountain Bike Review
In Barcelona for the New Intense Tazer [Italian]
New Star In The EMTB Sky? [German]
Best Mountain Bikes
Intense Tazer in comparison to averages
14 hours ago
21 hours ago
21 hours ago
