How to Overhaul a Jockey Wheel
Removal, lubrication and installation of a standard jockey (pulley) wheel.
In this tutorial we’ll learn how to overhaul a standard jockey wheel (pulley wheel) on your rear derailleur. In a future tutorial we’ll cover the sealed cartridge bearing style found on higher end derailleurs.
Tools
For this job you’ll typically need a 2.5 or 3mm allen key. Some older models have a nutted bolt requiring a metric wrench. You’ll also need a rag and some waterproof grease.
Pulley Removal
First you’ll want to remove the chain from the front chainring to give it some slack. You don’t need to remove the rear derailleur or cable for this job, but I will for this video so we can see things a bit better.
It is important to note that the upper and lower pulley wheels are different, so they should be overhauled one at a time to avoid a mix-up. The upper wheel will often have a thicker profile.
Remove the jockey wheel’s bolt by unthreading the bolt counter-clockwise. Once the bolt is removed, the jockey wheel will slide out of the derailleur cage. There will be a cupped washer facing inward on either side. Remove these and then pull the bushing sleeve out from the center.
Cleaning
Now wipe all parts clean with a dry rag. You can use a little cleaning solvent if needed. Inspect the teeth on the jockey wheel. These ones are in good shape. If yours are broken or badly worn they will need replacing.
Lubrication & Installation
Before reinstalling, apply some grease to the bolt, bushing sleeve, and inside of the pulley wheel. Then slide the bushing back into the wheel and hold the cupped washers in place on either side while you place the wheel back into the derailleur cage. Then tighten the bolt to the specified torque: usually around 3 Newton Meters or 20 inch pounds.
Repeat the process as needed for the other jockey wheel. If for some reason both wheels are removed and the inner cage plate has come off, remember that the larger end of the cage plate always attaches to the lower pulley wheel.
Related Links
Recommended Tools
- Park Tool AWS-10 Folding Hex Wrench Set
- Park Tool HXS-1.2 Hex Wrench Set
- Super Lube White Grease Canister
- Park Tool Wrench Combo Set
Categories
Rear v-brake repair
Latest post 2 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 3 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 49) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Latest post 3 months agoMy Trike.jpg (Size: 57.65 KB / Downloads: 49) Wife Trike.jpg (Size: 60.74 KB / Downloads: 49) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Read moreTrek domane tyre
Read moreBianchi Oltre Pro Garmin Mount
Latest post 6 months agoI am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
