We have read all expert and user reviews on the Knog Blinder Road 400. In summary, this is what cyclists think.
- The Blinder Road 400's flashing patterns are highly visible during the day, according to a reviewer.
- Testers say this light illuminates the road sufficiently in low-light urban settings.
- The Blinder Road 400 is waterproof.
- Cutouts in this light's casing enhance side-on visibility.
- The Knog Blinder Road has an integrated USB connector, so no charging cable is needed.
- This light remembers the last mode used.
- This light can be mounted on 22-35mm handlebars, including those with aero profiles.
- Knog offers an optional adaptor to mount this light on the GoPro bracket found under many out-front computer mounts.
- Several owners say the plastic mounting clip breaks easily and after little use.
- The Blinder Road 400 isn't bright enough for high speeds on unlit roads, according to testers.
- On its brightest setting, this light has a runtime of only one hour.
- The Blinder Road 400 charges using the old USB-A standard, not the increasingly popular USB-C.
- This light occupies around 2" of the handlebar.
- The soft, rubberized finish attracts dust.
Knog’s Blinder Road 400 is a front bike light with four modes and high and low settings. It fits 22–35mm round and aero handlebars. Owners and testers deem it sturdy and easy to use, but some say the mounting clip is fragile. The eye-catching flashing patterns are considered effective in urban settings, but the light isn't bright enough for high-speed rides in unlit areas. Short run times also limit this light's utility. Overall, testers consider the Knog Blinder Road 400 a good be-seen light but say similar, cheaper lights offer better value.Expert Reviews
82/100 based on 2 rated expert reviewsKnog Blinder Road 400 Dual LED Bicycle Headlight Review
Knog Blinder Road Lights (400 & 150 Lumen)
Best Bike Front Lights
Bike Light Comparison
3 hours ago
16 hours ago
