We have read all expert and user reviews on the Küat Beta. In summary, this is what cyclists think.
- Testers are impressed by the stability offered by the Küat Beta’s cam and threaded knob-screws, which tighten to reduce movement.
- The Küat Beta tilts forward 45° to allow owners to access their car’s rear door.
- The Beta collapses for compact storage.
- The Küat Beta carries 2 bikes, weighing as much as 40 lb each (80 lb combined).
- The Beta is available in both 2” and 1.25” hitch sizes.
- Many owners say the Beta is easy to assemble and install.
- Buyers found using and attaching the Beta to be a straightforward affair.
- Owners are impressed by the Beta’s protective, pearlescent, powder-coat finish.
- Buyers express their belief that the Küat Beta represents good value.
- Owners successfully used the Küat Beta for both road and mountain bikes.
4 reasons not to buy
- Testers and owners say the Beta isn’t easily compatible with step-through bikes.
- The Beta is limited to use with bikes that have an ample main frame triangle.
- Users need to remove the Beta’s pins to unfold the rack’s support arms.
- The Beta only comes in a 2-bike configuration.
The Küat Beta is deemed ‘best-in-class for hanging hitch-mount racks’, by a renowned mountain bike magazine. A number of owners recommend it. An innovative cam lock reduces wobble, along with two threaded knobs. Users will need an adapter for step-through bikes. Bikes with a small main triangle may not be compatible. At 14 lb, its low weight impresses. Testers point out that it isn’t as versatile as a tray rack, but that goes for all hanging hitch-mount racks. The Küat Beta folds down for rear door access and collapses for compact storage.BikeRide finds and shows you the best prices of the bikes you want to buy. Prices constantly change and it’s impossible to compare them all yourself.
93/100 based on 1 rated expert reviewAMB Reviews the Küat Bike Racks: NV 2.0, Transfer V2, Beta and Pivot
Küat Beta Bike Rack
Best Bike Vehicle Racks
Bike Rack Comparison
3 hours ago
5 hours ago
6 hours ago
