Küat Sherpa 2.0
94/100
We have read all expert and user reviews on the Küat Sherpa 2.0. In summary, this is what cyclists think.
  • Buyers feel the Sherpa 2.0 is “a fine piece of engineering” and worth the price.
  • Owners agree the Sherpa 2.0 is easy to install and remove.
  • The Sherpa 2.0 can tilt forward, allowing easier trunk access when bikes are mounted.
  • The rack's relatively low weight means it's easy to install without a second person. Multiple seniors highlight this as a key benefit.
  • Owners appreciate that the Sherpa 2.0 “doesn’t wobble” while driving.
  • Reviewers appreciate the aesthetics and color options.
  • This rack folds for tidier storage.
  • Küat offers a range of accessories to enhance functionality, including wall storage and a pivoting arm.
9 reasons not to buy
  • The rack is only for paved roads. Küat says it cannot be used on “unpaved surfaces.”
  • Experts and owners say the tilt latch is “a pain” to reach.
  • The rubber on the ratchet arm gets “chewed up” with use. Some owners report it detaching.
  • The rack may block license plates and backup cameras on certain vehicles.
  • Multiple owners say their exhaust melted the plastic ratchet arm positioned close to it.
  • Owners must buy an adaptor to transport bikes with wheels between 20” and 24.”
  • One expert demonstrates that bikes can easily fall inward and damage the trunk upon lifting the ratchet arm, as it's positioned on the outside. Users must constantly hold the mounted bikes to prevent this.
  • Küat only uses 20 different locks for the hitch lock on all units sold, so the possibility of theft is higher.
  • Küat warns that the Sherpa 2.0 is not compatible with all RVs.
The Küat Sherpa 2.0 is a platform hitch rack available for 1.25” or 2” hitches. Experts and reviewers praise the stability, sleek design, low weight, and ease of use. Potential buyers should consider license plate visibility and the distance to their vehicle’s exhaust pipe. Complaint center around the plastic ratchet arm that wears quickly and allows the bikes to fall inward once lifted. While it’s not designed for driving off-road, those in need of a stable, lightweight hitch rack for general transportation of bikes under 40lb find it worth the considerable price.
Categories
Rack Type
Maximum Load Capacity
Maximum Weight Per Bike
40 lb
Vehicle Type
32, 35 lb
Material
Aluminum, Steel
84/100 based on 4 rated expert reviews
100
Beauty and the Beast MTB
Küat Sherpa 2.0 Bike Hitch Rack Review, Unboxing, and Assembly
It’s probably one of the easiest accessories I’ve ever set up.
Review Chick
Küat Sherpa 2.0 Review – The Best Hitch Rack on the Market? [Video 3/3]
[It’s] probably the best one-and-one-quarter hitch racket on the market right now.
The Sherpa is an awesome competitor and a favorite amongst our testers for its simple, lightweight design… For those committed to non-electric bikes and standard tire sizes, the Sherpa is a good rack. It should also be on your shortlist if you frequently remove your rack…
Küat Sherpa 2.0 Bike Rack
If you need a sturdy, useful bike rack and value the peace of mind that comes with a well-known brand, you won’t find a better choice than the Sherpa 2.0… We’ve used four racks in the last year… the Küat Sherpa 2.0 [is] our hands-down favorite.
RV - Simple Life
RV Addition | Küat Sherpa 2.0 Bike Carrier | 6-Month Review
We think it’s well worth the money… it’s very durable.
Alpha-Works-Tx
Küat Sherpa 2.0 2-Bike Rack – 6-Month Review With Three of My Favorite Features
Everything about this rack is awesome; no complaints
Mountain Bikes and Motorcycles
Dakine DLX Tailgate Pad vs. Küat Sherpa 2.0 Bike Rack: Which Is Better?
So, which do I prefer? Well, the hitch rack, but that’s only because it fits my needs better than the tailgate pad.
Knobby Nomad
Küat Sherpa 2.0 Details (Video 2)
… I couldn’t recommend this more highly.
family handyman
Küat Bike Rack Review 2024, According to an Avid Biker
… the Sherpa 2.0 is a moderately priced, durable bike rack that is supremely easy to use… If you need to carry kid’s bikes, e-bikes, or fat-tire bikes, I recommend looking into other options…
The Cycling Independent
A Useful Review – The Küat Sherpa 2.0 Rack
You can spend less on a rack. [This one] is pricey, but I have not seen one cheaper that does all the things as well as this one does.
Küat Sherpa 2.0 – Review
… the new Sherpa is a definite step forward from the original. Our first Sherpa lasted for five years… [and] we suspect this Sherpa will do the same.
Küat Sherpa 2.0
The quality of a Küat rack does not come cheap. Even as the second-tier rack in Küat’s range, the Sherpa 2.0 will set you back [a chunk of change], but it is built to last.
95/100 based on 989 ratings
    86%
    8%
    2%
    2%
    2%
Bike Rack Comparison
Küat Sherpa 2.0 in comparison to averages
