Lectric XP 2.0
79/100
4, 6 Hours
45 Miles
60 Nm
48V 9.6Ah
64.0 lb
We have read all expert and user reviews on the Lectric XP 2.0. In summary, this is what cyclists think.
21 reasons to buy
  • Reviewers said the XP 2.0 is an excellent value.
  • The XP 2.0 comes fully assembled.
  • With a throttle and 5 levels of assist, the XP 2.0 is quick to accelerate.
  • The XP 2.0 folds for ease of storage and transport.
  • 20” wheels accelerated quickly from a dead stop, on the XP 2.0.
  • The XP 2.0 uses fat 3.0” tires that are versatile across terrains.
  • An easy-to-use interface displays trip distance, odometer, voltage and current on the XP 2.0.
  • The XP 2.0 can be manually adjusted to achieve 28mph as a Class 3 e-bike.
  • On the XP 2.0, the battery can be removed, for charging or security reasons.
  • The XP 2.0’s 630mm handlebar extends width over the XP’s 575mm bar, for better handling.
  • Reviewers found that the XP 2.0 offered a large range of seat and handlebar adjustment.
  • The XP 2.0 is fitted with mounting points for baskets and racks.
  • On the XP 2.0, integrated front and rear lights are included.
  • The XP 2.0 includes a front coil suspension fork, that wasn’t fitted to the 1.0.
  • A rear rack with a 75 lb payload comes included with the XP 2.0.
  • The Lectric XP 2.0 places riders in a comfortable, upright seating position.
  • Lectric XP 2.0 models comfortably fit riders between 5'0" and 6'3".
  • Fenders come included on all XP 2.0 models.
  • Motors on XP 2.0 models provide a powerful 800W peak output and plenty of torque.
  • The XP 2.0 has a carrying capacity of 330 lb.
  • Reviewers approved of Lectric’s one-year warranty and the quality of customer support for XP 2.0 owners.
  • The XP 2.0’s small 20” wheels roll slower and less smoothly than larger options.
  • Small wheels and a compact frame made the XP 2.0’s handling a little twitchy.
  • The keyhole used to activate the XP 2.0 is difficult to access.
  • XP 2.0 models are heavy and may need two people to lift.
  • Folding the XP 2.0 can be cumbersome. Its width makes it unwieldy to carry.
  • A tester was unnerved to find the motor kept running after they stopped pedaling.
  • The XP 2.0’s display is not removable, making it easy to steal.
  • There is no locking mechanism or strap to secure the folded XP 2.0.
The XP 2.0 can be manually switched between a Class 2 speed limit of 20mph and a roaring 28mph Class 3 limit. Reviewers were impressed at maintaining a high average speed of 16.3 mph, on the XP 2.0. The bike suits riders with a wide height range, from 5’0” to 6’3”. This bike arrives fully assembled. Buyers only need to unfold the XP 2.0, adjust handlebar and seat heights and pump up the tires. The XP 2.0’s low price impressed riders and reviewers. The Lectric XP 2.0 shares the same frame, motor, battery and wheel size as the 1.0. But it has been blessed with a coil suspension fork, wider handlebars and mounting points for racks and baskets. The 2.0 uses narrower and more agile 3.0” tires. The 7-speed Tourney drivetrain and Tektro brakes operated well after months of use. For most users, range distance consistently sat at around 23 to 25 miles.
79/100 based on 2 rated expert reviews
Lectric XP Step-Thru 2.0 Review
The Lectric XP 2.0 features numerous improvements that make it even better than the original. It may have the same frame and motor, but the addition of a suspension fork, wider handlebar, and narrower 3-inch wide tires have improved its handling and overall ride quality. This Class 2 and 3 capable bike is quick, comfortable, and comes with loads of great features at what we feel is a very reasonable price.
Review: Lectric XP
If stairs aren’t something you have to deal with on a regular basis, and you can lift 63 pounds, this is one of the best and most affordable ways to wade into the e-bike world.
Electric Bike Review
Lectric eBikes Lectric XP Step-Thru Review
One of the most affordable folding fat tire electric bikes from a company with dedicated customer support and a solid one-year warranty.
Lectric XP Step-Thru Review, 2021
This is easily one of the better e-bikes you can buy for under a thousand dollars: it’s powerful, it has great battery life, and it’s foldable.
Lectric XP Review – 2021
This bike comes with a powerful rear hub motor, grippy fat tires, and comes in at a price that is sure to make anyone happy.
Lectric XP 2.0 Review: Your First Electric Bike
If someone looking to buy their first e-bike were to ask me which one to get and that weren’t sure how much they were gonna ride it or where they were going to ride it, I would tell them to heavily consider the Lectric XP, mostly for how many features you get for the price.
KevCentral
Lectric XP 2.0 – Best Just Got Better? 28mph 500W 20×3.0 Fat Tire Folding Electric Bike
My initial impressions of this new Lectric XP 2.0, very nice bike. The 2.0 is 2.Go!
Electrified Reviews
Lectric XP Electric Bike Review: Best Folding Electric Bike Under $1000!
The Lectric XP folding fat tire electric bike is an incredibly affordable offering with formidable specs and plenty of functionality.
DavidBrandNew
5 Reasons Why the Lectric XP Is Not for You
The XP is not for you extreme off-roader dudes.
Jeremiah Mcintosh
Lectric 2.0 Electric Bike Detailed Overview and First Ride Impressions
It does seem like it has pretty good power.
Jeremiah Mcintosh
Lectric Ebike 500W Geared Hub Motor vs Rambo 500W Truck Run Mid-Drive Motor up Hills
We’re going to be putting the Lectric XP 500-watt rear-hub-motor e-bike up against the Rambo Cruiser 500-watt mid-drive motor and we’re going to be doing a hill test with them… pretty impressive that the Lectric beat me… I really thought the Rambo was gonna win… The Rambo Cruiser definitely climbed up steep hills a lot easier… I definitely recommend the mid-drive if you have a lot of inclines that you’re constantly climbing up.
Jeremiah Mcintosh
Rambo Cruiser Mid-Drive Ebike Test and Lectric Step-Thru First Trail Ride of the Year!
One of the main differences that I’ve noticed so far is the Lectric comes with a rack and fenders… Yes, [the Rambo Cruiser] is a lot more money but…there is a pretty good advantage on one thing on that bike and that’s the mid-drive motor and the torque that it has… You’re not going to beat the price and free shipping that [the Lectric] has… The noise of [the Cruiser’s] motor is very quiet…the way the pedal-assist kicks in is more fluid than on the Lectric… Do I think [the Cruiser] is worth over double the price? In my opinion, at [this price], no I do not.
DavidBrandNew
Lectric 2.0: Is It Worth the Extra Money?
The obvious upgrade on the 2.0 is that it comes with front suspension. That alone is worth the extra $100.
Fate Unbound
Fast & Fun! – Improved Lectric XP 2.0 E-bike – Folding E-bike Review
What blows my mind is with all of the upgrades they’ve made, all of the build quality improvements, all of these additions these bikes are still the exact same price as the previous model.
Big Truck Big RV
Lectric XP 2.0 Ebikes! Amazing Upgrades and Value for a Quality Ebike!
In my opinion this is the best value e-bike you can buy on the market.
Reflections of Our Life
Lectric XP Review / Good for Big People?
The longest ride that I have taken at my weight, about 20 miles. It was on a rail trail in West Virginia. It was pretty flat. I still had over half the battery left.
Wandering Wagners
Lectric XP 2.0 Ebike At Maumee Bay
I like how you can fold them up. They both fit in the back of the Jeep.
Chris Crossed
Lectric XP 2.0 Deep Dive Review With Ride Footage & Commentary
It comes with a 9.6 Ah battery which should be good for about 40 miles in the lowest PAS (pedal assist setting), but if you’re like me you ride in mainly PAS 2 to 3, you’re more likely to see that reduced to around 30 miles in real-world conditions. Going up hills, it’s great.
Long Long Honeymoon
Our New Foldable Electric Bikes! Lectric XP 2.0 Review
The price is actually very affordable. I think most people would call them an entry-level electric bike but in my opinion, you’re getting a lot of bike for the money.
EnjoyTheJourney.Life
Ebike Review | 2021 Lectric XP 2.0 Electric Folding Bicycle
These are just great for anyone who wants some exercise but maybe not the grueling bike workout.
1StrangeAdventure
Our Lectric XP 2.0 Ebikes Have Arrived!
Whether you’re short or tall these things will work for you.
Lectric eBikes Lectric XP Step-Thru. Review
Ultra affordable folding electric fat bike that looks pretty nice.
CleanTechnica
The Lectric Step-Thru 2.0 Folding E-Bike
The Lectric was designed to be as capable as possible at as low a price point as possible and considering what you get for the price in this second version, it is an impressive value.
TwinCities.com
The Lectric XP Electric Bike Is a Bit Crude, but Has Quality Where It Counts
Its messy frame welding, exposed cabling, cheap-feeling manual shifter, and other unrefined characteristics show where the maker cut corners to keep costs down.
Lectric XP 2.0 in comparison to averages
