Lectric XP 3.0 Long-Range
70/100
3, 4, 6, 7, 8, 12, 14, 16 Hours
65 Miles
30 mph
55 Nm
48V 14Ah
64.0 lb
We have read all expert and user reviews on the Lectric XP 3.0 Long-Range. In summary, this is what cyclists think.
17 reasons to buy
  • Reviewers are pleased that the bike comes commuter-ready; with integrated front and rear lights, steel fenders & a rear rack.
  • A frame-integrated rack carries up to 150lb.
  • With restrictions removed, this bike reaches 30mph via pedal assist.
  • The bike’s 500W motor produces almost 1000W at peak.
  • With a 20A controller, this bike puts out 55Nm of torque.
  • One tester notes smooth transition between assist levels.
  • Reviewers see the XP 3.0 Long-Range as an affordable option.
  • The bike is available with either a step-through or stepover frame.
  • With a 14Ah battery, Lectric say the bike can cover up to 65 miles of range.
  • Braking impressed. Testers like to see 180mm brake rotors.
  • Testers praise the gear range provided by the bike’s 11-28t freewheel.
  • A 50mm-travel suspension fork provides cushioning over moderate judder.
  • The bike folds down for ease of storage and/or transport.
  • Reviewers say 3.0” tires provide extra comfort at lower pressures.
  • A tester says the bike’s monochrome display is easy to see in daylight.
  • One tester says this is the quietest e-bike he has ever encountered.
  • One tester expresses their awe over this bike’s “beautiful” paintwork and finish.
  • The battery died at 22 miles for one tester. Others reached around 30 miles.
  • A tester’s rear brake started smoking under hard use.
  • Two testers found the bike’s brakes to be consistently noisy.
  • At 65lb, the XP 3.0 Long-Range is heavy and awkward to carry when folded.
  • The bike must be folded in order to remove the battery.
  • A reviewer says the bike’s non-lockable grips spin on handlebars easily.
The Lectric XP 3.0 Long-Range is identical to the XP 3.0, with the exception of a larger 14Ah battery. Lectric say this battery can attain up to 65 miles of range. Testers reached 22-30 miles under real-world use. Reviewers said brakes were powerful, but some testers complained of noisiness. One tester’s rear brake started smoking on a descent. Compared to the XP Long-Range 2.0, the 3.0 has:
  • An 11-28t Freewheel (vs. 14-28t on the 2.0).
  • A 50mm suspension fork (vs. 40mm).
  • 180mm brake rotors (vs. 160mm).
  • Hydraulic brakes.
But perhaps most importantly, it now has a frame-integrated rack capable of carrying 150 lb of cargo (or a passenger, with an aftermarket passenger kit).
88/100 based on 3 rated expert reviews
Lectric XP 3.0 Review: Yes! The Best Affordable E-Bike Just Got Better
Lectric is known for taking its customers’ feedback into consideration. With the 3.0 they did just that. It’s objectively a better electric bike with no change to the price. We kind of recommend just going with the Long-Range, it helps you fight that range anxiety right off the bat. We do really think it is worth it.
Jeremiah Mcintosh
Lectric XP 3.0 Long-Range E-Bike Review ~ One of the Best Selling Lectric Bicycles Just Got Better!
Very impressed overall with just the rad quality, the smoothness of the pedal assist levels. One of the quietest bikes that I’ve ever tested. Very similar power to the 2.0. Loving that 11-28t freewheel. The brakes definitely need some improvements. The back pad back brake is smoking. The battery is dead. I went 22 miles. It has tons of power.
Lectric XP 3.0 Long Range Folding Step Thru 1000W Electric Bike Review
Really just the perfect bike for getting around town, grabbing groceries, running errands. It’s certainly a big upgrade from the 2.0 but my only gripe with this bike is the cheap brakes. They make a lot of noise, they squeal. This thing is wicked cheap.
KevCentral
Lectric XP 3.0 – An Honest Review of the New 28+ MPH Folding E-Bike!
This is a better all-around bike than any XP before it. Because I only had a day with this bike before I got this footage all together, I’ve only had 25 miles of actual riding and in that time I only lost two bars out of the full battery meter and that’s on throttle-only in pedal assist level five.
Pedal With Power
Lectric XP 2.0 vs 3.0 – What’s the Difference? Side-By-Side Comparison!
New fork has 50 mm of travel… 3.0 brakes now come with 180 mm rotors… The 3.0 comes stock with the 11-28t freewheel. 2.0 hub motor: 35 Nm of torque. This new one: 55 Nm. The whole rack is now part of the frame… this can now support up to 150 lb. The controller went from 18A to 20A.
Chris Elenes
30 MPH!!! Lectric XP 3.0 Top Speed Test 🤩🤯
Let’s see how fast we can go… Fast bike! 30 mph. We’re on level ground too.
Chris Elenes
Lectric XP 3.0 – Ride To Seal Beach – Range Test – 30 Mile Ride
30-mile plus round trip from Downey to Seal Beach. Real-world test, running the lights and all on pedal assist level four. What an amazing experience! We got a bar left, we’re gonna make it home, just in time for dinner too.
20/100 based on 1 ratings
#430 Best Electric
Bottom 10%
#86 Best Folding
Bottom 10%
#9 Best Lectric Bike
Bottom 20%
#793 Best of All Bikes
Bottom 10%
Lectric XP 3.0 Long-Range in comparison to averages
70
