We have read all expert and user reviews on the Lezyne Connect Smart 1000XL / KTV. In summary, this is what cyclists think.
- The Smart Connect 1000XL and KTV have aluminum casing, which experts say feels sturdy.
- Lezyne’s LED Ally app is easy to use, according to reviewers.
- The app shows battery life and allows users to sync the lights and customize, remove, and toggle modes.
- Experts say the rear light’s flash mode is easy to see in daylight.
- Testers find the 1000XL front light offers sufficient brightness for seeing at night, though not at high speeds or on very technical terrain.
- Experts praise the beam spread and reach of the 1000XL headlight.
- Testers appreciate the side-on visibility of both lights.
- The battery life of both lights is good, according to reviewers.
- Some owners say the rubber straps are too short to fit wide-diameter handlebars and seatposts, and Lezyne doesn’t offer guidance on max dimensions.
- The front light can move (depending on bar diameter) when riding on rough off-road terrain.
- Charge time is long at five hours for the rear light and up to eight for the front light.
- Charging the KTV Drive Pro involves removing it from the bike, taking off the casing, and plugging it into a USB-A port.
- A tester complains that the 1000XL’s rubber strap is integrated, so the whole unit must be removed when not in use.
- These lights cannot be used while charging.
The Lezyne Connect Smart 1000XL / KTV bike light set includes a 1000lm front and 75lm rear light. Both can be paired with Lezyne’s app to sync, customize, and remove modes. Testers praise the easy-to-use app, the battery life, the brightness for night riding, and side-on visibility. However, the mounting straps are too short for some bars and seatposts, and the front light may move on rough off-road terrain. Charging the rear light is also fiddly, and charge times for both lights are lengthy. Nonetheless, experts and owners agree that the Connect Smart 1000XL / KTV set is good value.BikeRide finds and shows you the best prices of the bikes you want to buy. Prices constantly change and it’s impossible to compare them all yourself.
1.5 to 160 Hours
83/100 based on 3 rated expert reviewsLezyne Connect Smart 1000XL / KTV Pro Smart Pair Lights Review
Lezyne Connect Smart 1000XL/KTV Pro Smart Lights
Lezyne Lite Drive 1000XL and KTV Pro Light Set Review
Lezyne Connect Smart Pairs Front and Rear Lights for Mountain Biking at Night [Review]
Best Bike Light Sets
Bike Light Comparison
12 hours ago
