important: Nuts and bolts on your bike should always be tightened to the manufacturer's specifications.
How to Lubricate Brake and Shift Cables
Cable lubrication is recommended, especially if you ride in the rain or have old cable housings.
Most brake and shift cables these days have a plastic lining built into the housing, therefore eliminating the need for lubrication. However, if you ride a lot in wet weather, or have an older bike without the plastic lining, you’ll want to lubricate the cables to prevent rust. I personally believe that well-lubricated cables also improve braking and shifting.
Lubricant
I use Tri-flow to lubricate cables, as it is very effective at distributing itself evenly, and lasts a long time. Most bike shops carry it, or they may have a similar product that will work just as well. Make sure you shake the bottle before use, and have a rag handy to wipe off any excess.
Brake Cable Lubrication
Most brake and derailleur systems have some sort of quick release system that allow you to release the cable from it’s stop. Here it is demonstrated on a cantilever brake, but other systems like sidepull, U-brakes, and V-brakes have similar quick release mechanisms.
Once the brake is released, compress the lever, pull on the housing, and slide it through the barrel adjuster until the inner wire is exposed. Now carefully squeeze a few drops of oil onto the inner cable just above where it runs down into the housing. If the cable is vertical, the oil will penetrate the housing on its own.
Slide the cable housing back into the barrel adjuster and re-connect the brake.
Shifter Cable Lubrication
Rear Shift Cable
To lube the rear shift cable, first shift the gears until the chain is on the largest sprocket, and then stop the wheel from rotating.
With the freewheel stopped from moving, shift your shifter all the way in the opposite direction, as if you were going to shift to the smallest sprocket. The rear derailleur should now be stuck on the largest sprocket, which will give you enough slack to fully release the cable from the frame. Pull the upper section of the outer cable down leaving a section of inner cable exposed. Lube the cable the same way as the brake cable, and then reconnect the outer housing.
Now pull the lower section of housing free from the frame, and slide it away from the derailleur. Repeat the lubrication process and reconnect the housing. Don’t forget to move your rear shifter back to the largest sprocket before rotating the rear wheel.
Front Shift Cable
To lube the front shift cable, shift the front derailleur to the largest sprocket, and then stop the crank from rotating and move the shift lever all the way in the opposite direction. Disconnect and lube the upper housing of the front shift cable the same way as the rear. Reconnect the cable and once again make sure to shift the lever back where it was before rotating the crank.
Related Links
Recommended Tools
Categories
Rear v-brake repair
Latest post 3 days ago
Hi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Read more
Custom Bike part manufacturing
Latest post 4 weeks ago
Hello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Read more
I have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down.   IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50)   IMG_20250122_105428.jpg (...
Read more
Hi everyone! I hope you're enjoying a great start to 2023. I'm curious to hear your go-to method for getting a chain truly clean. I don't mean, just looks shiny or is good enough for a quick clean after a ride. I want to know what you do when you want to get every last morsel of ground-up, link-destroying, roller-eating, tooth-gnashing crud out of your chain. The Best Chain-Cleaning Recipe Ever?...
Read more
What jockey wheel Red 10 Speed
Latest post 2 months ago
Can anyone advise what type of replacement jockey wheel I need for a 10 speed Red rear mech (it's got 11 teeth)? Bonus points if it's a link to a cheap (ish) one! Thanks...
Read more
Grip Shifters
Currently renovating a child's bike. It has 24 inch wheels and is a suitable size for a 7-10 year old. Anyway it has grip shifters. it is a six speed with three chain rings on the front derailleur. On the rear derailleur the shifter does not appear to move the gear cable at all when shifting from 6 to 5 and 5 to 4. I am actually holding the cable with my finger and thumb against the cable cas...
Read more
9 speed chain on 8 speed bike
All of my bikes are 7 or 8 speed and sometime in the past I bought a 9 speed chain for some unremembered reason. is there any reason not to use it on an 8 speed bike?...
Read more
Operation of Santa Monica Ebike
Latest post 3 months ago
Hello - new owner with an How to Operate the bike question. Hopefully, this is easily answered I Bought this bike a few weeks ago - Tested many bikes and finally landed on this particular Santa Monica. However, got busy with Christmas shopping, Life, and not so great weather days distracted me from riding. I also test drove so many that I forgot how to operate it.... I "thought" I remembered, ...
Read more
Gears and derailleur misalignment
  My Trike.jpg (Size: 57.65 KB / Downloads: 50)   Wife Trike.jpg (Size: 60.74 KB / Downloads: 50) Although I have ridden bikes on and off since a kid (75 years old now), I have very little experience with anything other than a single speed bike. I recently purchased a new 7-speed Gospel adult tike, which needed assembly. My wife has the same model trike but older and p...
Read more
I'm curious—how often or after how many miles do people typically check or change their mechanical disc brake pads? I've been bikepacking for a while but never really followed a maintenance schedule. A few weeks ago, I took my bike to a mechanic because I heard some noise. The mechanic did a quick overhaul, and I was sent on my way. However, a few weeks later, while descending steep hills, I s...
Read more
Shifting is almost impossible
Latest post 4 months ago
My wife's road bike has Shimano Sora shifters with a triple front derailleur (stock). The thumb switch on the front shifter is VERY hard to use and she can't do it when she's riding. I did a full adjustment of the front derailleur but it didn't change anything. One thing that I noticed is that the shifter works smoothly when the shifter cable is unattached from the derailleur, suggesting that the ...
Read more
7-speed bicycle with bent rim
Latest post 5 months ago
I recently bought a 7-speed bicycle practically brand new it still has a little rubber nipples on the tires apparently it got backed into in the garage and it bent the rear rim sideways my question is can I go out and buy another just like single speed 20 inch bicycle and put the 7-speed cassette onto that rim?...
Read more
Trek domane tyre
Hi I have a trek domane 2.3, and I have changed the rear tyre to 28 (it was 25 originally) The tyre rubs with the brake arm (v brake), I fear it doesn’t seem to be compatible Is there any way to adjust the position of the brake arm? I just need it to ne around 2mm higher Thanks...
Read more
Schwinn meridian rear drive axle
Recently bought a slightly used 26" meridian trike. While replacing wider tires on the rear, I noticed an issue with the rear drive side wheel hub. The wheel is held on with a nut and single washer. The hub is not held firmly in a location on the axle and is able to slide back and forth on the axle a good half inch even though the nut is tightened all the way down to its bottom threads on the axle...
Read more
Bianchi Oltre Pro Garmin Mount
Latest post 6 months ago
I am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
