Magicycle Commuter
80/100
4 Hours
40 Miles
350 W
45 Nm
52V 7Ah
43 lb
We have read all expert and user reviews on the Magicycle Commuter. In summary, this is what cyclists think.
  • Experts laud the Magicycle Commuter's belt drive for its quiet operation and low maintenance requirements.
  • Reviews demonstrate the 350W motor's ample power, climbing well and easily reaching 20mph.
  • The mechanical disc brakes with 180mm rotors exhibit strong stopping power in testing.
  • The Commuter e-bike is relatively lightweight at 43lb.
  • Testers appreciate the agility and maneuverability.
  • The Commuter is available in both step-through or step-over frame configurations.
  • Users value the bike's design, integration, and finely done paint job.
  • Riders describe the Magicycle Commuter as a highly enjoyable and fun ride.
  • Riding the bike without pedal assist is practical, in one reviewer's opinion.
10 reasons not to buy
  • The real-world range falls short of Magicycle's stated range of 40 miles. One tester achieved 22 miles using pedal assist level 2.
  • The single-speed gearing and absence of a throttle means starting from a dead stop is more challenging.
  • An expert says the battery indicator is inaccurate, dropping significantly after 15 miles.
  • The non-removable battery can make charging inconvenient.
  • The Magicycle Commuter has a high minimum height of 5'7".
  • Multiple users report inner tubes exploding despite being within the correct pressure range.
  • The small rear rack, designed for pannier bags only, is described as incomplete and impractical by some users.
  • The taillight isn't built-in and requires manual charging.
  • The Commuter lacks mounting options for a bottle holder.
  • One expert reports excessive battery loss while the bike is not in use.
The Magicycle Commuter is a Class 1 single-speed electric bike available as a step-over or step-through. It features a quiet belt drive and 350W motor and earns praise for its climbing performance and stopping power. Users also appreciate the looks, low maintenance needs, simplicity, and city-friendly design. Some drawbacks include limited range and gearing, low-quality inner tubes, and battery fluctuations. However, despite these flaws, experts feel the Commuter is a fun and practical option for urban commuting at an affordable price.
87/100 based on 2 rated expert reviews
Russ Is Right
The Magicycle Commuter E-Bike Takes on Hills!!
The Magicycle Commuter e-bike takes on hills without a problem!
EbikeProducts
Magicycle’s Belt-Drive Commuter E-Bike! Full Review and Ride Footage With 52 Volts/350 Watts!
… impressive is that this is one of the first few bikes I’ve seen that has a 52-volt battery powering a 350-watt motor.
Russ Is Right
What’s the Magicycle Commuter E-Bike’s Range? – 52 Volts, 7Ah Battery With a 350-Watt Motor
… it doesn’t matter that it’s 350W; I’m still doing decent speed on this bike.
Russ Is Right
First Look: The New Magicycle Commuter E-Bike!
I was surprised at how well I was able to ride a single-speed, Class 1 e-bike with a belt drive!
Russ Is Right
Why I Like the Magicycle Commuter E-Bike So Much
… it’s the most simplistic bike! I feel like I’m on a regular bike that has no assist or anything, but I know the motor is there helping me.
68/100 based on 5 ratings
    20%
    40%
    20%
    20%
#334 Best Electric
Bottom 30%
#21 Best Single Speed - Fixed Gear
Bottom 40%
#4 Best Magicycle Bike
Bottom 30%
#614 Best of All Bikes
Bottom 30%
Magicycle Commuter in comparison to averages
