We earn affiliate commission.
Learn more
23.6, 23 lb
We have read all expert and user reviews on the Marin Cortina AX1. In summary, this is what cyclists think.
- The Cortina AX1’s handling was said to be quick, predictable and dynamic on gravel and rutted tracks.
- The timeless minimalism of Marin’s retro paintjob garnered attention and praise.
- An alloy frame and carbon fork proved a comfortable combination. Aluminum ribs in the frame and fork acted as a heat sink to cool off disc brakes.
- Attention to detail resulted in an admirable finish.
- Schwalbe G-One tires came tubeless-ready and are reportedly easy to setup, with decent speeds reached on snow and ice.
- The Cortina’s adaptable nature saw it performing well on gravel, roads and cyclocross proper.
- Quick-release Naild 12-3-9 thru-axles allowed precise and replicable removal and reattachment of wheels.
- The aforementioned thru-axles, in 15mm (front) and 12mm (in the rear), provided stiff action.
- A myriad of bosses, eyelets and mudguard mounts accommodate full racks, full-length mudguards and accessories.
- Generous clearance allows for tires up to 50mm wide, or 40mm with mudguards.
- Even the most ardent Cortina lovers noted that it wasn’t the cheapest option, considering Tiagra kit and mechanical discs.
- One expert said the bike felt overgeared on technical descents and spun-out on flats. On higher gears, the Tiagra drivetrain may have problems with a jumping chain.
- The TRP Spyre mechanical disc brakes were fitted with semi-metallic pads that one expert saw as being suited to mud, but too hard for general road and gravel conditions.
- Some Cortinas were fitted with Schwalbe G-One tires, which were considered less grippy than X-Ones.
- The Cortina wasn’t considered a lightweight. This led one expert to suggest shedding some pounds by replacing the stock wheels.
Marin’s Cortina AX1 is a well-thought-out performer that incorporates some compromises to deliver an affordable package. Handling and comfort were lauded, as were its throwback aesthetics (if you’ve ever seen a 1991 Marin Palisades, you’ll get my drift). The bells and whistles are found on its older sibling, the AX2. The AX1 isn’t the lightest or cheapest in class, but it is an incredibly sound machine that will only be elevated by customization and upgrades.Expert Reviews
85/100 based on 2 rated expert reviewsMarin Cortina AX1
Test: Marin Cortina AX 1 – CX or Gravel? [Polish]
Marin Cortina AX
Gravel and adventure bikes with the highest BikeRide Scores
Marin Cortina AX1 in comparison to averages
4 hours ago
1 day ago
1 day ago
