Mobo Triton Pro
83/100
44.0 lb
We have read all expert and user reviews on the Mobo Triton Pro. In summary, this is what cyclists think.
11 reasons to buy
  • The Triton Pro was favored as a rehabilitation aid, by people suffering from back and neck problems.
  • Riders found this trike easy to adapt to and control.
  • The Triton Pro is adjustable, allowing it to be used by shorter and taller riders. It also suits growing children and teens.
  • Riders said the seat was comfortable and padding was ample.
  • This vehicle was great for riders with a disability, special needs or a balance impairment.
  • Assembly was often easy and instructions were ample. This took anywhere from twenty minutes to an hour. Some chose to follow the YouTube instructions. The trike comes with tools.
  • The adjustability of the Triton means that it can be partially collapsed for transport or storage.
  • Some owners said that they were too afraid to ride a bicycle. The Triton sidestepped this fear.
  • This trike comes provided with an orange safety flag, to assist visibility.
  • Multiple owners described the Triton as sturdy.
  • The price of the Triton was declared to be ‘reasonable’. It was seen as a cheap alternative for those that didn’t need a full recumbent.
18 reasons not to buy
  • Tires (especially the rear two) were reported to wear out quickly. They needed replacing in anywhere from two weeks to six months, or from thirty to sixty miles use.
  • Some complainants mentioned that the geometry didn’t provide for adequate back and neck support.
  • A major issue with the Triton is that it can’t be ridden up anything but the most moderate gradient. The front wheel loses traction and lifts off the ground on uphills.
  • The Triton has no gears. Both the manufacturer and riders say that it is intended for flat ground. It was regularly said to be undergeared and slow.
  • Some owners felt that this trike was overpriced.
  • There were issues with the alignment of the rear wheels, which led to problems with coasting. This necessitated ordering a custom part from the manufacturer.
  • Some folk felt that the saddle was thin and uncomfortable.
  • The Triton’s steel construction meant that it was quite heavy.
  • Because it’s low to the ground, some individuals with disabilities had difficulty mounting and unmounting the Triton.
  • The Triton’s turning-circle was reported to be quite wide.
  • A number of owners found the instructions difficult to follow.
  • Stickers and decals were said to be crooked and tacky. Some chose to remove them.
  • Packaging wasn’t always great. Damage included dented fenders, bent forks, missing screws and scratches.
  • Numerous owners were disappointed that warranties were only valid for thirty days.
  • In a number of instances, the screws holding the seat fell out.
  • Riders over 6’2” found the Triton unrideable. Those with large feet said that their heels dragged on the ground.
  • Some construction issues were apparent. Parts were welded incorrectly or upside-down, making the trike unusable.
  • The Triton suffered from poor traction, particularly on gravel, where the wheels spun-out.
Here is a human-powered vehicle that fits within a very specific niche. The Triton Pro was most appropriate for older riders, people with disabilities, those with special needs or individuals suffering or recovering from injuries. It was specifically mentioned that it was easy to ride for those who were autistic, epileptic or who suffered from multiple sclerosis. It was also suitable for riders with Down Syndrome, special needs or impaired balance. The elderly and chronically unfit used it as a low-impact rehabilitation aid. The Triton is a low-geared singlespeed tricycle and is not a replacement for a recumbent. Long-distances and hills are not an option.
Dope or Nope
Mobo Pro. Dope or Nope?
Recumbent Trike
That’s a neat concept. Poor man’s recumbent.
John In the Desert
Mobo Trikes
…this is real simple so there’s no balance required… and then, we’ll get him on a bike eventually.
83/100 based on 534 ratings
    61%
    19%
    7%
    5%
    8%
#3 Best Recumbent Trike
Bottom 50%
#69 Best Seniors
Bottom 50%
#3 Best Mobo Bike
Bottom 30%
#452 Best of All Bikes
Bottom 50%
Mobo Triton Pro in comparison to averages
