Mokwheel Mesa Plus ST
68/100
5.5 Hours
55 Miles
65 Nm
48V 16Ah
71 lb
We have read all expert and user reviews on the Mokwheel Mesa Plus ST. In summary, this is what cyclists think.
  • The Mesa Plus ST comes in two frame sizes to fit riders from 5’4” to 6’4”, according to Mokwheel.
  • A tester enjoys the Mesa Plus ST’s impressive hill-climbing ability.
  • The low step-through frame is easy to mount.
  • The handlebars are height and reach adjustable, allowing for a range of rider sizes and riding positions.
  • This bike comes with fenders, lights, a horn, and a kickstand.
  • Mokwheel includes a pump and most of the tools needed for assembly.
  • The 660mm wide handlebar provides good control and stability, according to a reviewer.
  • The Mesa Plus ST has a 350lb payload capacity.
  • One reviewer’s bike suffers numerous problems out of the box, including a broken motor, rust on the rack and seatpost clamp, paint damage caused by poor packaging, and ill-fitting fenders.
  • According to a tester, Mokwheel says it’s “normal” for oil to leak from the fork. This is not normal.
  • A tester gets the bike to 31mph using pedal assist. This exceeds the Class 3 speed limit and could be illegal.
  • Mechanical disc brakes are a bad joke on a bike that weighs 71 pounds and can exceed 28mph. A reviewer says braking requires a lot of effort at the levers.
  • As one expert highlights, the electrical wiring and cables run under the bottom bracket without protection, leaving them highly vulnerable to knocks.
  • Mokwheel suffers from dismal owner feedback, with complaints about poor customer support and faulty products.
  • The Mesa Plus ST has a cargo rack, but Mokwheel doesn’t say how much weight it can carry.
  • While riding off-road, a reviewer’s handlebar comes loose despite the clamp having been fully tightened.
Mokwheel's Mesa Plus ST is an electric fat bike with a step-through frame, 750W motor, and 768Wh battery. Experts appreciate the accessible frame, good hill-climbing power, and impressive turn of speed. However, the mechanical brakes are underpowered, the fork is clunky, and the off-road ability is poor. Worst of all, one reviewer's test bike demonstrates why Mokwheel has a poor reputation for quality control and customer support. It has a broken motor, rust in several areas, a leaking fork, and shipping damage to the frame. There is little to recommend the Mokwheel Mesa Plus ST. Shoppers should look elsewhere.
68/100 based on 2 rated expert reviews
HeroesNStuff
Best E-Bike for Safety & Speed? Electric Bike Review Mokwheel Mesa Plus – All-Terrain Fat Tire 31MPH
… if this is your first time riding an e-bike and you want an all-terrain option, this would be a great bike for you.
Dustin Dunnill
Mokwheel Mesa ST Plus E-Bike Review – Unbox/Setup/Ride Test
This is one of the kind of higher end Mokwheels and you would think… getting more of a quality premium product, but it just looks like they need more quality control. It’s a cool-looking bike, but it needs work.
#437 Best Electric
Bottom 10%
#224 Best Fat Tire
Bottom 10%
#10 Best Mokwheel Bike
Bottom 10%
#811 Best of All Bikes
Bottom 10%
Mokwheel Mesa Plus ST in comparison to averages
