We earn affiliate commission.
Learn more
Type
26.7 lb
We have read all expert and user reviews on the Motobecane UNO Outcast. In summary, this is what cyclists think.
5 reasons to buy
- The Outcast's low price buys you a steel frame, disc brakes and decent components.
- Frame clearance allows for tires up to 42c in width.
- The Outcast UNO Pro features Shimano MT200 hydraulic brakes.
- Owners called the Outcast a “good-looking bike”.
- The gear ratio was well-suited to cruising and pavement use.
3 reasons not to buy
- A long wheelbase meant less whippy handling than the Fantom Cross Uno.
- An irregular 26 mm seatpost could be less stiff than a standard 27.2 mm post.
- While the Outcast could come across as a rigid mountain bike, it isn’t built for real singletrack.
The Outcast came across as a comfortable and reliable commuter that can easily be ridden on hardpack dirt and moderate gravel, with the stock Kenda or WTB Riddler tires. A lower-cost option features mechanical disc brakes, while the ‘Pro’ uses Shimano MT200 hydraulic discs. Owners generally saw the bike as a versatile flat-land commuter or runabout.Expert Reviews
0/100 based on 0 rated expert reviews2020 Motobecane Outcast UNO Pro
Best Single Speed and Fixed Gear Bikes
Single speed and fixed gear bikes with the highest BikeRide Scores
Motobecane UNO Outcast in comparison to averages
11 hours ago
11 hours ago
12 hours ago
