We have read all expert and user reviews on the Niner WFO E9. In summary, this is what cyclists think.
13 reasons to buy
- The Niner WFO E9 has a reliable and durable Bosch motor, providing riders with three levels of pedal-assist.
- The bike has a high-quality aluminum frame.
- The aluminum frame has a lifetime warranty on the WFO E9.
- Niner utilizes aluminum in the frame of the WFO E9 because it manages the heat produced by the motor and battery better than carbon e-bike frames.
- The bike has a 29-inch wheel and tire in the front paired with a 27.5-inch setup in the rear. This setup allows the rider to roll over obstacles with ease.
- The Maxxis Minion DHF in the front and Maxxis Aggressor tire in the rear provide riders with fantastic traction over rough off-road terrain.
- Niner utilizes SRAM RE brakes with 200mm rotors to provide riders with excellent stopping power.
- The Horst Link suspension provides riders with 180mm of travel. The coil shock is quick to respond to big hits.
- The WFO E9 has a 12-speed SRAM drivetrain that is made specifically for e-bikes.
- The long wheelbase and slack geometry of the bike provide riders with stability on descents.
- Weighing in at 54.75 lbs., the weight of the WFO E9 does not prevent riders from overcoming technical obstacles in their path.
- The bike is a Class 1 e-bike, with pedal assist up to 20mph. Experts found that they could easily exceed this speed on the bike.
- Experts state that the bike is an affordable, quality e-bike in its category.
2 reasons not to buy
- The bike comes with a 125 mm dropper. Experts suggest upgrading to a longer dropper post.
- One expert found the WFO E9 hard to maneuver through tight turns.
The Niner WFO E9 is a self-shuttling downhill mountain bike. The bike has 180mm of travel with its Horst Link suspension set up. The bike has a durable and reliable 4th Generation Bosch Line CX motor. The aluminum frame on the bike has a lifetime warranty and manages the heat from the motor and battery better than carbon. The bike has three levels of pedal-assist and an e-bike specific 12-speed SRAM drivetrain. The bike is long, making it hard to maneuver through tight corners. Experts found the bike affordable.Expert Reviews
80/100 based on 1 rated expert reviewNiner WFO E9 Review
Niner WFO E9: Park the Truck
My First Experience With This Brand, and They Sent Their Longest Travel Bike…
Best Mountain Bikes
1 day ago
