We earn affiliate commission.
Learn more
4.5 Hours
26 Miles
70 Nm
36V 14Ah
52.34, 53.50 lb
We have read all expert and user reviews on the Norco Range VLT. In summary, this is what cyclists think.
- The Range’s ability to handle big hits and air was praised.
- 180mm of front travel make this a downhill beast.
- Stability and traction were lauded on descents.
- The RockShox Super Deluxe Coil shock proved well-balanced.
- One tester found the bike comfortable on long exploratory rides.
- A steep seat-tube angle paid off on climbs.
- Maxxis Assegai tires were plenty grippy and never spun out.
- An optional range extender gives riders a total capacity of almost 1,000 Wh.
- The long BikeYoke dropper-post aided stability on descents.
- The rear brake rotor sometimes rubbed on the frame.
- An undersized chainstay protector allowed paintwork damage.
- The Range’s battery can’t be removed from the bike.
- One tester felt that the Range’s seating position felt unsuited to long rides.
- A long frame and wide bars felt overextended to some riders.
- One reviewer had the rear shock blow-out after two rides.
- A SRAM rear derailleur required replacement after one test ride.
A steep seat-tube angle, slack head angle and long top-tube matched the Range to fast downhill runs, as did the plentiful suspension and softer-compound rear tire. This bike was most at home shredding on descents, but testers also found it capable on climbs. Riders were usually exhausted before being able to deplete the 630Wh battery. This e-MTB is mostly suited to aggressive riding, where it generally impressed.Expert Reviews
67/100 based on 1 rated expert reviewNorco Range VLT C1 in Review
Norco Range VLT C1 eMTB Review
Did Norco Make the Best Ebike? Norco Range VLT C1
Racing the Lift
Did I Like the Norco Range Better Than the Giant?
2020 Best E-bike I Ever Ridden
Can I Out-Ride a 630 Watt Battery? 2020 Norco Range Ebike Battery Test.
Best Mountain Bikes
Norco Range VLT in comparison to averages
10 hours ago
17 hours ago
17 hours ago
