Orbea Oiz
90/100
If you find a lower price, email us at contact@bikeride.com with documentation of the price. We’re committed to making sure that the cost of a bike does not keep you from cycling!
21.74 lb
We have read all expert and user reviews on the Orbea Oiz. In summary, this is what cyclists think.
15 reasons to buy
  • The Orbea Oiz is available with a carbon or aluminum frame, placing the bike in a wide range of rider's budgets.
  • Weighing in at just 21.75 lbs., the bike is light and easy to maneuver.
  • A shorter rear end allows riders to corner smoothly on the bike.
  • The Orbea Oiz can be customized in great detail, using the MyO feature on Orbea’s website.
  • Internal cable routing and flat-mounted disc brakes are minor details found on the Oiz, that make it sleek and attractive in appearance.
  • The Squidlock allows riders to easily toggle between open, medium and firm to adjust the suspension of the Oiz, as they ride.
  • Orbea utilizes a SRAM UDH derailleur hanger on the bike. This makes it easy to find and replace the derailleur hanger, wherever one can find a SRAM dealer.
  • Despite not having a suggested weight limit on the Oiz, Orbea still includes a lifetime warranty on all frames.
  • Testers were pleased to find that two water bottles can fit in sizes medium and larger, making this bike great for endurance riding.
  • Maxxis Rekon tires provide excellent traction on rocky and wet terrain, for riders of the Oiz.
  • Wide handlebars, grippy tires and the bike’s geometry provide riders with a stable riding position for climbing through technical terrain.
  • The Oiz is forgiving. Experts found it easy to correct mistakes on the trail, at the last second.
  • With its steep geometry, the bike is efficient on climbs.
  • With short chainstays, the bike is confident and easy to guide on descents.
  • Testers agree that the bike is affordable for the components included with each build. There a variety of builds available, to fit differing component preferences.
2 reasons not to buy
  • Orbea does not include a dropper post with XC models of the Oiz.
  • One tester noted that the 160mm rear brake rotor was on the small side. Riders would benefit from upgrading to a 180mm rear rotor.
The Orbea Oiz is a sleek bike, best suited for cross-country trails. The XC version of the bike has 100mm travel. The TR version has 120mm of travel. With Orbea's MyO customization tool, riders can customize both the color and components on the bike. Testers found the Oiz easy to maneuver up tight technical climbs. It has wide handlebars and grippy tires that provide riders with stability for confident descents. Unfortunately, only TR models of the bike come with a dropper post. The rear brake rotor is also on the small side, according to one expert.
90/100 based on 1 rated expert review
Orbea Oiz M-LTD Review
The Oiz clearly deserves its position as one of the top XC full-suspension bikes right now.
Flow Mountain Bike
Review: The 2021 Orbea Oiz Is a Race Bike With an Ace up Its Sleeve
With the latest Oiz, Orbea has produced one of the most well-rounded full suspension XC race bikes currently on the market. Yes, it’s very lightweight and yes, it also looks fabulous. But it’s the handling, suspension quality and smart spec that makes this such a versatile performer on the trail.
The MTB Garage
The Best Cheap “Down-Country” Bike? Orbea Oiz H20 Review
It’s good for cross-country riders that want a bike that’s a little bit more versatile, that can handle descending with a little bit more confidence, but still be super-efficient to climb with.
Mossie Rides Bikes
Orbea Oiz M30 Long Term Review
As far as a cross-country bike, I have been nothing but pleased.
brujulabike
We Tested the Orbea Oiz M-LTD 2021, One of the Great Stars of the World Cup
In short, this is one of the lightest full suspension bicycle frames on the market due to the 250g reduction in the weight of the whole, thanks to the use of OMX carbon and the new swingarm, without losing any stiffness. It has a balanced geometry, plus the shortened 5 mm seat stays to make it even more responsive.
Orbea Oiz in comparison to averages
