How to Overhaul Wheel Bearings
Overhaul a hub, replace and grease the wheel bearings, and adjust the cones.
This tutorial will demonstrate how to grease your wheel bearings. For this job you’ll need some rags, waterproof grease, and a 17mm open-end wrench. You’ll also need a 13mm cone wrench for a front hub, and a 15mm cone wrench for a rear hub. When overhauling a hub, you should always replace the ball bearings. Most front hubs need 10 3/16″ bearings per side, while rear hubs usually need 9 1/4″ bearings.
Dis-Assemble Hub
If you’re overhauling the rear hub, you’ll need to remove the cassette or freewheel before you begin. Carefully remove any seals that may be protecting the cone and locknut.
Place the wheel on its side and slide a cone wrench onto the cone flats, and then loosen the left, or non-drive side locknut by turning it counter-clockwise against the cone wrench. Completely un-thread and remove the cone and locknut, and then slide the axle out from the right side of the hub.
Clean Hub Parts
Clean all of the old grease off of the axle and cones and remove all of the bearings from both sides, making sure to count how many you take out. Then clean the inside of the hub and carefully inspect both the cones and the inner bearing races. If there is any damage such as pitting then the cone and/or hub should be replaced.
Grease Hub and Bearings
Apply a generous layer of grease to both of the hub’s bearing races. Then carefully insert all of the new bearings by pushing them down in the grease. When all of the bearings are installed, there should be about half a bearing space left. Cover all of the bearings with a layer of grease and lightly grease the axle threads.
Re-Assemble Hub
Once the bearings are installed on both sides, carefully slide the axle into hub, making sure the bearings stay in place. Thread the left side cone, washer (if any) and locknut all the way on finger tight.
Adjust Cone and Locknut
Now lay the wheel back on its side and place the cone wrench on the cone. Tighten the locknut against the cone and check to make sure there is no play in the hub, and that the wheel spins freely. You may have to loosen the locknut and repeat the procedure many times before it is correct. Quick release mechanisms tighten the cones slightly, so if you have a quick release axle, you’ll have to leave a slight bit of play in the hub.
Re-install any seals and then put the wheel back on your bike. Finally, check the adjustment again by moving the wheel side to side at the rim. Again, there shouldn’t be play in the wheel, and it should spin smoothly.
Related Links
- Jim Langley: Overhauling hubs
- Park Tool: Hub Overhaul and Adjustment
- Sheldon Brown: Overhauling & Repacking Hubs
Recommended Tools
- Park Tool SCW-SET.3 Cone Wrench Set
- Park Tool Wrench Combo Set
- Super Lube White Grease Tube
- Finish Line Grease Gun
- Super Lube White Grease Canister
- Park Tool CB-4 Bio ChainBrite
Categories
Rear v-brake repair
Latest post 4 days agoHi everyone, I'm new here and I've been trying to avoid taking my bike to a mechanic and save some money. I succesfully fixed my front but struggle with the rear, I got new brakes for the rear. I notice i think it might be the housing causing the noodle to be off centered and making the left brake pad to close to the rim. Any help would be greatly appreciated, thanks!! My next project is to attemp...
Latest post 4 weeks agoHello, Not sure if I should post this in buying advice or repairs, but here we are. I recently bought Schwinn cruiser an old one and I can't find the rear dropout bracket replacement. So I decided to try out a custom bike part manufacturer. Still waiting for my part, so if anyone has tried out a custom on demand manufacturer, please share your experience....
Latest post 1 month agoI have a Gazelle Esprit belt drive bike with hub gears which has a rear puncture. Can someone advise me on how to remove and refit the wheel? I'm aware that it can be quite complicated, but I have no option other than tackling it myself. The photos were taken with the bike upside down. IMG_20250122_105320.jpg (Size: 77.51 KB / Downloads: 50) IMG_20250122_105428.jpg (...
Read moreGrip Shifters
Read moreTrek domane tyre
Read moreBianchi Oltre Pro Garmin Mount
Latest post 6 months agoI am wondering if anyone can help me with the garmin mount that came with my recently purchased Bianchi Oltre Pro. I was on a ride descending and the mount flew off, landing in the middle of the road with my garmin head unit. Luckily the head unit still works with a few minor scratches and cracks. From the picture you can see that it was not that the screws came loose, it was in fact the part of ...
Read more
